WiFi- Unable to setup MDNS on SoftAP for ESP32
Krishan T S
Postby Krishan T S » Tue Jan 18, 2022 7:12 am
I am trying to setup DNS for ESP32 in Access point mode (Using SoftAP), It is not working. My code is
const char* host = "example";
void setupWifi()
  WiFi.mode(WIFI_AP);
  WiFi.softAP("SSID","Password");
  Serial.println(WiFi.softAPIP());
setupWifi();
MDNS.begin(host);
if (!MDNS.begin(host)) {
    Serial.println("Error startng mDNS responder");
  else {
    Serial.println("mDNS server started");
Any other approaches are there for setting up DNS in AP mode for ESP32 ?
esp1979
Re: WiFi- Unable to setup MDNS on SoftAP for ESP32
Postby esp1979 » Sat Jan 22, 2022 8:44 pm
I have the same question/problem.
mDNS in station mode works but in AP mode or in my case WIFI_AP_STA mode does not work ;-(
Really no one that can help?
Best wishes
Daniel
pataga
Postby pataga » Fri Jan 28, 2022 2:45 am
What OS are you using for access ?
As far as I know only MacOS has built in support for mDNS. For Windows you need to install Bonjour, for Ubuntu you need to install Avahi.
mkeveney
Postby mkeveney » Thu Feb 03, 2022 2:20 am
I know this is an old query, but I just ran into it.
Found an answer here: https://github.com/espressif/esp-idf/issues/4369
(...but still can't get my Android device to use mDNS unfortunately.)
