How to use a2db souce audio stream after deinit pipeline?
victor_a333
Postby victor_a333 » Mon Jan 24, 2022 1:15 pm
Hello friends,
Board ESP32 LyraT. tested on esp-idf 4.3.2 and 4.4. and latest esp-adf.
My audio project has playback and paththrouse mode. I want to switch audio output beetwen I2S and BT . I can switch output from I2S(esp-adf\examples\advanced_examples\flexible_pipeline) to BT . But I have no audio after reinit bt source stream with connected speaker.
How I can reinit BT audio stream to use in second pipeline?
Thank you very much!
monitor log
I (3756) BLUETOOTH_SOURCE_EXAMPLE: a2dp connecting to peer: HD600
W (3756) BT_APPL: reset flags
E (5406) BT_APPL: bta_av_rc_create ACP handle exist for shdl:0
W (5496) BT_APPL: new conn_srvc id:18, app_id:0
W (5506) BT_APPL: new conn_srvc id:18, app_id:1
W (6516) A2DP_STREAM: AVRC ct remote features 24b
W (6516) A2DP_STREAM: AVRC tg remote features 24b, CT features 1
W (163026) FATFS_STREAM: No more data, ret:0
W (163306) BT_APPL: ### UNDERFLOW :: ONLY READ -2 BYTES OUT OF 512 ###
W (163306) BLUETOOTH_SOURCE_EXAMPLE: [ * ] Bluetooth disconnected or suspended
W (163306) BT_APPL: btc_media_aa_prep_sbc_2_send underflow 11, -2
I (163306) BLUETOOTH_SOURCE_EXAMPLE: [ 7 ] Stop audio_pipeline
W (163316) BT_APPL: un-acked a2dp cmd: 3
E (163326) AUDIO_ELEMENT: [file] Element already stopped
E (163326) BT_APPL: bta_av_str_stopped:audio_open_cnt=1, p_data 0x3f80f3f4
E (163336) AUDIO_ELEMENT: [mp3] Element already stopped
W (163346) BT_APPL: ### UNDERFLOW :: ONLY READ -2 BYTES OUT OF 514 ###
W (163346) AUDIO_PIPELINE: There are no listener registered
W (163356) BT_APPL: btc_media_aa_prep_sbc_2_send underflow 21, -4
W (163356) AUDIO_ELEMENT: [bt] Element has not create when AUDIO_ELEMENT_TERMINATE
W (163376) AUDIO_ELEMENT: [file] Element has not create when AUDIO_ELEMENT_TERMINATE
W (163366) BT_APPL: un-acked a2dp cmd: 3
W (163386) AUDIO_ELEMENT: [mp3] Element has not create when AUDIO_ELEMENT_TERMINATE
W (163386) BT_APPL: Media task Scheduled after Suspend
I (163396) BLUETOOTH_SOURCE_EXAMPLE: [3.0] Create audio pipeline2 for playback
I (163406) BLUETOOTH_SOURCE_EXAMPLE: [3.1] Create fatfs stream to read data from sdcard
I (163416) BLUETOOTH_SOURCE_EXAMPLE: [3.2] Create mp3 decoder to decode mp3 file
W (163426) BT_BTC: btc_avrc_ct_init already initialized
I (163426) BLUETOOTH_SOURCE_EXAMPLE: [3.4] Register all elements to audio pipeline
W (163436) BT_BTC: btc_avrc_tg_init already initialized
I (163436) BLUETOOTH_SOURCE_EXAMPLE: [3.5] Link it together [sdcard]-->fatfs_stream-->mp3_decoder-->bt_stream-->[bt sink]
I (163456) BLUETOOTH_SOURCE_EXAMPLE: [3.6] Set up  uri (file as fatfs_stream, mp3 as mp3 decoder, and default output is i2s)
I (163466) BLUETOOTH_SOURCE_EXAMPLE: [4.1] Listening event from all elements of pipeline
I (163476) BLUETOOTH_SOURCE_EXAMPLE: [4.2] Listening event from peripherals
E (163486) AUDIO_EVT: Error add queue items to queue set
I (163496) BLUETOOTH_SOURCE_EXAMPLE: [ 5 ] Start audio_pipeline
I (163506) BLUETOOTH_SOURCE_EXAMPLE: [ 6 ] Listen for all pipeline events
I (163596) BLUETOOTH_SOURCE_EXAMPLE: [ * ] Receive music info from mp3 decoder, sample_rates=44100, bits=16, ch=2
E (170576) BT_APPL: bta_dm_pm_btm_status hci_status=36
My test example from pipeline_a2dp_source_stream
play_bt_source_example.c
/* Play music from Bluetooth device
#include <string.h>
#include "esp_log.h"
#include "esp_wifi.h"
#include "esp_peripherals.h"
#include "esp_gap_bt_api.h"
#include "nvs_flash.h"
#include "sdkconfig.h"
#include "audio_element.h"
#include "audio_pipeline.h"
#include "audio_event_iface.h"
#include "board.h"
#include "mp3_decoder.h"
#include "a2dp_stream.h"
#include "fatfs_stream.h"
#define BT_CONNECT_TIMEOUT      20000
typedef uint8_t esp_peer_bdname_t[ESP_BT_GAP_MAX_BDNAME_LEN + 1];
static const char *TAG = "BLUETOOTH_SOURCE_EXAMPLE";
static esp_peer_bdname_t remote_bt_device_name;
static bool device_found = false;
static esp_bd_addr_t remote_bd_addr = {0};
static char *bda2str(esp_bd_addr_t bda, char *str, size_t size)
    if (bda == NULL || str == NULL || size < 18) {
        return NULL;
    uint8_t *p = bda;
    sprintf(str, "%02x:%02x:%02x:%02x:%02x:%02x",
            p[0], p[1], p[2], p[3], p[4], p[5]);
    return str;
static bool get_name_from_eir(uint8_t *eir, uint8_t *bdname, uint8_t *bdname_len)
    uint8_t *rmt_bdname = NULL;
    uint8_t rmt_bdname_len = 0;
    if (!eir) {
        return false;
    rmt_bdname = esp_bt_gap_resolve_eir_data(eir, ESP_BT_EIR_TYPE_CMPL_LOCAL_NAME, &rmt_bdname_len);
    if (!rmt_bdname) {
        rmt_bdname = esp_bt_gap_resolve_eir_data(eir, ESP_BT_EIR_TYPE_SHORT_LOCAL_NAME, &rmt_bdname_len);
    if (rmt_bdname) {
        if (rmt_bdname_len > ESP_BT_GAP_MAX_BDNAME_LEN) {
            rmt_bdname_len = ESP_BT_GAP_MAX_BDNAME_LEN;
        if (bdname) {
            memcpy(bdname, rmt_bdname, rmt_bdname_len);
            bdname[rmt_bdname_len] = '\0';
        if (bdname_len) {
            *bdname_len = rmt_bdname_len;
        return true;
    return false;
static void filter_inquiry_scan_result(esp_bt_gap_cb_param_t *param)
    char bda_str[18];
    uint32_t cod = 0;
    int32_t rssi = -129; /* invalid value */
    uint8_t *eir = NULL;
    esp_peer_bdname_t peer_bdname;
    esp_bt_gap_dev_prop_t *p;
    ESP_LOGI(TAG, "Scanned device: %s", bda2str(param->disc_res.bda, bda_str, 18));
    for (int i = 0; i < param->disc_res.num_prop; i++) {
        p = param->disc_res.prop + i;
        switch (p->type) {
            case ESP_BT_GAP_DEV_PROP_COD:
                cod = *(uint32_t *)(p->val);
                ESP_LOGI(TAG, "--Class of Device: 0x%x", cod);
            case ESP_BT_GAP_DEV_PROP_RSSI:
                rssi = *(int8_t *)(p->val);
                ESP_LOGI(TAG, "--RSSI: %d", rssi);
            case ESP_BT_GAP_DEV_PROP_EIR:
                eir = (uint8_t *)(p->val);
                get_name_from_eir(eir, (uint8_t *)&peer_bdname, NULL);
                ESP_LOGI(TAG, "--Name: %s", peer_bdname);
            case ESP_BT_GAP_DEV_PROP_BDNAME:
            default:
    ESP_LOGI(TAG, "need device name %s", (uint8_t *)remote_bt_device_name);
    /* search for device named "peer_bdname" in its extended inquiry response */
    if (eir) {
        if (strcmp((char *)peer_bdname, (char *)remote_bt_device_name) != 0) {
            return;
        ESP_LOGI(TAG, "Found a target device, address %s, name %s", bda_str, (uint8_t *)peer_bdname);
        device_found = true;
        memcpy(&remote_bd_addr, param->disc_res.bda, ESP_BD_ADDR_LEN);
        ESP_LOGI(TAG, "Cancel device discovery ...");
        esp_bt_gap_cancel_discovery();
static void bt_app_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)
    switch (event) {
        case ESP_BT_GAP_DISC_RES_EVT: {
                filter_inquiry_scan_result(param);
        case ESP_BT_GAP_DISC_STATE_CHANGED_EVT: {
                if (param->disc_st_chg.state == ESP_BT_GAP_DISCOVERY_STOPPED) {
                    if (device_found) {
                        ESP_LOGI(TAG, "Device discovery stopped.");
                        ESP_LOGI(TAG, "a2dp connecting to peer: %s", remote_bt_device_name);
                        esp_a2d_source_connect(remote_bd_addr);
                        // not discovered, continue to discover
                        ESP_LOGI(TAG, "Device discovery failed, continue to discover...");
                        esp_bt_gap_start_discovery(ESP_BT_INQ_MODE_GENERAL_INQUIRY, 10, 0);
                } else if (param->disc_st_chg.state == ESP_BT_GAP_DISCOVERY_STARTED) {
                    ESP_LOGI(TAG, "Discovery started.");
        case ESP_BT_GAP_PIN_REQ_EVT: {
                ESP_LOGI(TAG, "ESP_BT_GAP_PIN_REQ_EVT min_16_digit:%d", param->pin_req.min_16_digit);
                if (param->pin_req.min_16_digit) {
                    ESP_LOGI(TAG, "Input pin code: 0000 0000 0000 0000");
                    esp_bt_pin_code_t pin_code = {0};
                    esp_bt_gap_pin_reply(param->pin_req.bda, true, 16, pin_code);
                    esp_bt_pin_code_t pin_code = {'1', '2', '3', '4'};
                    esp_bt_gap_pin_reply(param->pin_req.bda, true, 4, pin_code);
        default:
    return;
void app_main(void)
    audio_pipeline_handle_t pipeline;
    audio_element_handle_t fatfs_stream_reader, bt_stream_writer, mp3_decoder;
    esp_log_level_set("*", ESP_LOG_WARN);
    esp_log_level_set(TAG, ESP_LOG_INFO);
    esp_err_t err = nvs_flash_init();
    if (err == ESP_ERR_NVS_NO_FREE_PAGES) {
        // NVS partition was truncated and needs to be erased
        // Retry nvs_flash_init
    ESP_LOGI(TAG, "[ 1 ] Mount sdcard");
    // Initialize peripherals management
    esp_periph_config_t periph_cfg = DEFAULT_ESP_PERIPH_SET_CONFIG();
    esp_periph_set_handle_t set = esp_periph_set_init(&periph_cfg);
    // Initialize SD Card peripheral
    audio_board_sdcard_init(set, SD_MODE_1_LINE);
    ESP_LOGI(TAG, "[ 2 ] Start codec chip");
    audio_board_handle_t board_handle = audio_board_init();
    audio_hal_ctrl_codec(board_handle->audio_hal, AUDIO_HAL_CODEC_MODE_DECODE, AUDIO_HAL_CTRL_START);
    ESP_LOGI(TAG, "[3.0] Create audio pipeline for playback");
    audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    pipeline = audio_pipeline_init(&pipeline_cfg);
    mem_assert(pipeline);
    ESP_LOGI(TAG, "[3.1] Create fatfs stream to read data from sdcard");
    fatfs_stream_cfg_t fatfs_cfg = FATFS_STREAM_CFG_DEFAULT();
    fatfs_cfg.type = AUDIO_STREAM_READER;
    fatfs_stream_reader = fatfs_stream_init(&fatfs_cfg);
    ESP_LOGI(TAG, "[3.2] Create mp3 decoder to decode mp3 file");
    mp3_decoder_cfg_t mp3_cfg = DEFAULT_MP3_DECODER_CONFIG();
    mp3_decoder = mp3_decoder_init(&mp3_cfg);
    ESP_LOGI(TAG, "[3.3] Create Bluetooth stream");
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_FIXED;
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_BLE));
    ESP_ERROR_CHECK(esp_bt_controller_init(&bt_cfg));
    ESP_ERROR_CHECK(esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT));
    ESP_ERROR_CHECK(esp_bluedroid_init());
    ESP_ERROR_CHECK(esp_bluedroid_enable());
    esp_bt_dev_set_device_name("ESP_SOURCE_STREAM_DEMO");
    esp_bt_gap_set_pin(pin_type, 4, pin_code);
    esp_bt_gap_register_callback(bt_app_gap_cb);
    const char *remote_name = {"HD600"};
    //remote_name = CONFIG_BT_REMOTE_NAME;
    if (remote_name) {
        memcpy(&remote_bt_device_name, remote_name, strlen(remote_name) + 1);
        memcpy(&remote_bt_device_name, "ESP_SINK_STREAM_DEMO", ESP_BT_GAP_MAX_BDNAME_LEN);
    a2dp_stream_config_t a2dp_config = {
        .type = AUDIO_STREAM_WRITER,
        .user_callback = {0},
    bt_stream_writer = a2dp_stream_init(&a2dp_config);
#if (ESP_IDF_VERSION >= ESP_IDF_VERSION_VAL(4, 0, 0))
    esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
#else
    esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
#endif
    ESP_LOGI(TAG, "[3.4] Register all elements to audio pipeline");
    audio_pipeline_register(pipeline, fatfs_stream_reader, "file");
    audio_pipeline_register(pipeline, mp3_decoder, "mp3");
    audio_pipeline_register(pipeline, bt_stream_writer, "bt");
    ESP_LOGI(TAG, "[3.5] Link it together [sdcard]-->fatfs_stream-->mp3_decoder-->bt_stream-->[bt sink]");
    const char *link_tag[3] = {"file", "mp3", "bt"};
    audio_pipeline_link(pipeline, &link_tag[0], 3);
    ESP_LOGI(TAG, "[3.6] Set up  uri (file as fatfs_stream, mp3 as mp3 decoder, and default output is i2s)");
    audio_element_set_uri(fatfs_stream_reader, "/sdcard/test.mp3");
    ESP_LOGI(TAG, "[3.7] Create bt peripheral");
    esp_periph_handle_t bt_periph = bt_create_periph();
    ESP_LOGI(TAG, "[3.8] Start bt peripheral");
    esp_periph_start(set, bt_periph);
    ESP_LOGI(TAG, "[ 4 ] Set up  event listener");
    audio_event_iface_cfg_t evt_cfg = AUDIO_EVENT_IFACE_DEFAULT_CFG();
    audio_event_iface_handle_t evt = audio_event_iface_init(&evt_cfg);
    ESP_LOGI(TAG, "[4.1] Listening event from all elements of pipeline");
    audio_pipeline_set_listener(pipeline, evt);
    ESP_LOGI(TAG, "[4.2] Listening event from peripherals");
    audio_event_iface_set_listener(esp_periph_set_get_event_iface(set), evt);
    ESP_LOGI(TAG, "[ 5 ] Start audio_pipeline");
    audio_pipeline_run(pipeline);
    ESP_LOGI(TAG, "[ 6 ] Listen for all pipeline events");
    while (1) {
        audio_event_iface_msg_t msg;
        esp_err_t ret = audio_event_iface_listen(evt, &msg, portMAX_DELAY);
        if (ret != ESP_OK) {
            ESP_LOGE(TAG, "[ * ] Event interface error : %d", ret);
            continue;
        if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT
            && msg.source == (void *) mp3_decoder
            && msg.cmd == AEL_MSG_CMD_REPORT_MUSIC_INFO) {
            audio_element_info_t music_info = {0};
            audio_element_getinfo(mp3_decoder, &music_info);
            ESP_LOGI(TAG, "[ * ] Receive music info from mp3 decoder, sample_rates=%d, bits=%d, ch=%d",
                     music_info.sample_rates, music_info.bits, music_info.channels);
            continue;
        if (msg.source_type == PERIPH_ID_BLUETOOTH
            && msg.source == (void *)bt_periph) {
            if ((msg.cmd == PERIPH_BLUETOOTH_DISCONNECTED) || (msg.cmd == PERIPH_BLUETOOTH_AUDIO_SUSPENDED)) {
                ESP_LOGW(TAG, "[ * ] Bluetooth disconnected or suspended");
                periph_bt_stop(bt_periph);
    ESP_LOGI(TAG, "[ 7 ] Stop audio_pipeline");
    audio_pipeline_stop(pipeline);
    audio_pipeline_wait_for_stop(pipeline);
    audio_pipeline_terminate(pipeline);
    /* Terminal the pipeline before removing the listener */
    audio_pipeline_remove_listener(pipeline);
    /* Release all resources */
    audio_pipeline_unregister(pipeline, bt_stream_writer);
    audio_pipeline_unregister(pipeline, fatfs_stream_reader);
    audio_pipeline_unregister(pipeline, mp3_decoder);
    audio_pipeline_deinit(pipeline);
    audio_element_deinit(bt_stream_writer);
    audio_element_deinit(fatfs_stream_reader);
    audio_element_deinit(mp3_decoder);
    //Init second pipeline. same as first pipeline
    audio_pipeline_handle_t pipeline2;
    ESP_LOGI(TAG, "[3.0] Create audio pipeline2 for playback");
    pipeline2 = audio_pipeline_init(&pipeline_cfg);
    mem_assert(pipeline2);
    audio_pipeline_register(pipeline2, fatfs_stream_reader, "file");
    audio_pipeline_register(pipeline2, mp3_decoder, "mp3");
    audio_pipeline_register(pipeline2, bt_stream_writer, "bt");
    const char *link_tag2[3] = {"file", "mp3", "bt"};
    audio_pipeline_link(pipeline2, &link_tag2[0], 3);
    audio_pipeline_set_listener(pipeline2, evt);
    audio_pipeline_run(pipeline2);
    while (1) {
            continue;
            continue;
    audio_pipeline_stop(pipeline2);
    audio_pipeline_wait_for_stop(pipeline2);
    audio_pipeline_terminate(pipeline2);
    audio_pipeline_remove_listener(pipeline2);
    /* Stop all periph before removing the listener */
    esp_periph_set_stop_all(set);
    audio_event_iface_remove_listener(esp_periph_set_get_event_iface(set), evt);
    /* Make sure audio_pipeline_remove_listener & audio_event_iface_remove_listener are called before destroying event_iface */
    audio_event_iface_destroy(evt);
    audio_pipeline_unregister(pipeline2, bt_stream_writer);
    audio_pipeline_unregister(pipeline2, fatfs_stream_reader);
    audio_pipeline_unregister(pipeline2, mp3_decoder);
    audio_pipeline_deinit(pipeline2);
    esp_periph_set_destroy(set);
    esp_bluedroid_disable();
    esp_bluedroid_deinit();
    esp_bt_controller_disable();
    esp_bt_controller_deinit();
    esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT);
