esp32-lyrat-mini-v1.2使用asr无法唤醒求助
yuanjie
Postby yuanjie » Wed Jan 26, 2022 7:33 am
I (0) cpu_start: App cpu up.
I (927) heap_init: Initializing. RAM available for dynamic allocation:
I (934) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (940) heap_init: At 3FFB2BC0 len 0002D440 (181 KiB): DRAM
I (946) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (952) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (959) heap_init: At 4008D8EC len 00012714 (73 KiB): IRAM
I (965) cpu_start: Pro cpu start user code
I (982) spi_flash: detected chip: gd
I (982) spi_flash: flash io: qio
I (982) cpu_start: Starting scheduler on PRO CPU.
I (996) example_asr_keywords: Initialize SR wn handle
Quantized wakeNet5: wakeNet5X3_v2_nihaoxiaoxin_6_0.95_0.85, mode:0 (Oct 14 2020 16:26:17)
I (1009) example_asr_keywords: keywords: nihaoxiaoxin (index = 1)
Fail: index is out of range, the min index is 1, the max index is 1I (1016) example_asr_keywords: keywords_num = 1, threshold = 0.000000, sample_rate = 16000, chunksize = 480, sizeof_uint16 = 2
WARNING: Sample length must less than 5000ms in the SINGLE_RECOGNITION mode
SINGLE_RECOGNITION: 2_0 MN1_4; core: 0; (May 15 2020 14:50:27)
SHIFT: 8, 12, 17, 17, 19, 17, 6, 16, 15, 14,
I (1059) example_asr_keywords: keywords_num = 166 , sample_rate = 16000, chunksize = 480, sizeof_uint16 = 2
I (1061) example_asr_keywords: [ 1 ] Start codec chip
I (1567) example_asr_keywords: [ 2.0 ] Create audio pipeline for recording
I (1567) example_asr_keywords: [ 2.1 ] Create i2s stream to read audio data from codec chip
I (1588) example_asr_keywords: [ 2.3 ] Create raw to receive data
I (1588) example_asr_keywords: [ 3 ] Register all elements to audio pipeline
I (1592) example_asr_keywords: [ 4 ] Link elements together [codec_chip]-->i2s_stream-->raw-->[SR]
W (1703) I2C_BUS: i2c_bus_create:57: I2C bus has been already created, [port:0]
----------------------------- ESP Audio Platform -----------------------------
| ESP_AUDIO-v1.7.0-31-g5b8f999-3072767-09be8fe |
| Compile date: Oct 14 2021-11:00:34 |
I (1768) example_asr_keywords: esp_audio instance is:0x3ffd0b50
I (1768) example_asr_keywords: [ 5 ] Start audio_pipeline
HengYC
Re: esp32-lyrat-mini-v1.2使用asr无法唤醒求助
Postby HengYC » Wed Mar 09, 2022 2:50 am
你好,
请更新 ADF, 使用 WWE 例程, ASR 例程因为 esp-sr 更新不再支持了。
