ESP32 WROVER UART problem
Viktrrrr
Postby Viktrrrr » Mon Jan 31, 2022 1:02 pm
Hi there!
I have just a very little experience with ESP32 and its UART, tried it and ran into a problem. I want to test a KNX with ESP32, so I assembled a simple setup of 3 devices, made 2 NCN5120 devboards and tried to make ESP32 to communicate with KNX. But for some reason ESP reads a garbage. NCN is configured as 19200 8E1 and connected to GPIO 21/22 pins. Here's my MVE:
    ets_printf("\nStarting\nSDK version %s\n", esp_get_idf_version());
    uart_config_t uartConfig = {
        .baud_rate = 19200,
        .parity = UART_PARITY_EVEN,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
        .rx_flow_ctrl_thresh = 122,// Tried also 0
        .source_clk = UART_SCLK_APB // Tried also UART_SCLK_REF_TICK
    int uartPortNumber = 1; // Tried also 2
    int pinTx = 21;
    int pinRx = 22;
    uart_driver_install(uartPortNumber, 1024, 0, 0, NULL, 0);
    uart_param_config(uartPortNumber, &uartConfig);
    uart_set_pin(uartPortNumber, pinTx, pinRx, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    uart_set_baudrate(uartPortNumber, KNX_UART_SPEED);
    uart_set_word_length(uartPortNumber, UART_DATA_8_BITS);
    uart_set_parity(uartPortNumber, UART_PARITY_EVEN);
    uart_set_stop_bits(uartPortNumber, UART_STOP_BITS_1);
    uart_set_hw_flow_ctrl(uartPortNumber, UART_HW_FLOWCTRL_DISABLE, 0);
    uart_set_mode(uartPortNumber, UART_MODE_UART);
    uint8_t byte;
    byte = 1;
    if (uart_write_bytes(uartPortNumber, &byte, 1) != 1)
        ets_printf("Init writte error\n");
    else
        ets_printf("init written ok\n");
    if (uart_read_bytes(uartPortNumber, &byte, 1, 10000 / portTICK_RATE_MS) != 1 || byte != 3)
        ets_printf("Init response read error\n");
    else
        ets_printf("init response read ok\n");
    uint8_t address[4] = {0xf1, 0x41, 0x02, 0x00};
    if (uart_write_bytes(uartPortNumber, &address, 4) != 4)
        ets_printf("Assign address writte error\n");
    else
        ets_printf("Assign address written ok\n");
    if (uart_read_bytes(uartPortNumber, &byte, 1, 10000 / portTICK_RATE_MS) != 1 || byte != 0x21)
        ets_printf("Assign address response  read error\n");
    else
        ets_printf("Assign address response read ok\n");
    while (true)
        int res;
        res = uart_read_bytes(uartPortNumber, (void *)&byte, 1, 10000 / portTICK_RATE_MS);
        if (res == 1)
            ets_printf("%2.2X ", byte);
        else
            ets_printf("\n");
        vTaskDelay(1);
I did "read value" by ETS from one of the devices connected to the same bus. And here's its output:
SDK version 4.3.2
init written ok
47 BC 11 07 00 46 F5 54 14 B2 57
For testing I also make a simple MVE with Raspberry pi and Java/NRSerial and it works fine. Init:
int baudRate = 19200;
NRSerialPort serial = new NRSerialPort(portName, baudRate);
serial.setDataBits(8);
serial.setParity(SerialPort.PARITY_EVEN);
serial.setStopBits(SerialPort.STOPBITS_1);
serial.connect();
The same frame readings (correct):
Using port /dev/ttyAMA0
Sent reset, got response 0x03
Sent address, got response 0x21
BC 11 07 00 06 E1 00 00 B2
Probably I am doing something wrong when using ESP32's UART. Please advise how to do it correctly.
Thank you!
Viktrrrr
Re: ESP32 WROVER UART problem
Postby Viktrrrr » Mon Jan 31, 2022 8:50 pm
Sorry guys, my mistake. I simply forgot to connect common ground wire rofl
sorry, now everything is working fine
Users browsing this forum: Baidu [Spider], coccocbot, PerplexityBot, YisouSpider and 1 guest
