esp32 aws ota
icy_gau
esp32 aws ota
Postby icy_gau » Wed Feb 02, 2022 6:11 pm
hi, i was referring to aws ota demo using mqtt. im getting below error:
cmake -DVENDOR=espressif -DBOARD=esp32_devkitc -DCOMPILER=xtensa-esp32 -G Ninja -S . -B ..\build\
-- Configuring done
-- Generating done
-- Build files have been written to: C:/gau/AWS/ESP32/freertos-1643010662146/build
cmake --build ..\build\
C:\gau\AWS\ESP32\freertos-1643010662146\FreeRTOS>cmake --build ..\build\
[0/2] Re-checking globbed directories...
[2/1651] Building C object CMakeFiles/afr_crypto.dir/vendo...pressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj
FAILED: CMakeFiles/afr_crypto.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj
C:\Users\RHONAKAM\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DAFR_ESP_LWIP -DESP_PLATFORM -DIDF_VER=\"v4.3.1-dirty\" -DMBEDTLS_CONFIG_FILE=\"C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/include/mbedtls/esp_config.h\" -D_GNU_SOURCE -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/freertos_plus/standard/crypto/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/xtensa/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/soc/soc/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/soc/src/esp32/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/pkcs11 -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/mbedtls/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/mbedtls_config -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/mbedtls/include/mbedtls -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/mbedtls_utils -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/lwip/include/apps -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/lwip/include/apps/sntp -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/lwip/lwip/src/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/lwip/port/esp32/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/lwip/port/esp32/include/arch -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/lwip/lwip/src/include/compat -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/freertos_kernel/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/app_update/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/bootloader_support/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp32/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp_event/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/efuse/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/driver/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/heap/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/log/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/nvs_flash/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/pthread/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/newlib/platform_include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/soc/soc/esp32/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/soc/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/spi_flash/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/vfs/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp_ringbuf/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/boards/esp32/../components/freertos/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/xtensa/esp32/include/xtensa -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/xtensa/esp32/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp_rom/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp_timer/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp_common/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/esp_system/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/tcpip_adapter/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/boards/esp32/aws_demos/config_files/default_pkcs11_config -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/freertos_kernel/portable/ThirdParty/GCC/Xtensa_ESP32/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/demos/include -IC:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/boards/esp32/aws_demos/config_files -Iconfig -mlongcalls -Wno-maybe-uninitialized -std=gnu99 -Wno-old-style-declaration -Wno-stringop-overflow -Wno-bool-operation -Wno-sizeof-pointer-div -Wno-nonnull -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -Wno-parentheses -Wno-sizeof-pointer-memaccess -Wno-clobbered -Wno-format-overflow -Wno-stringop-truncation -Wno-misleading-indentation -Wno-cast-function-type -Wno-implicit-fallthrough -Wno-unused-const-variable -Wno-switch-unreachable -Wno-format-truncation -Wno-memset-elt-size -Wno-int-in-bool-context -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -MD -MT CMakeFiles/afr_crypto.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj -MF CMakeFiles\afr_crypto.dir\vendors\espressif\esp-idf\components\mbedtls\port\esp32\bignum.c.obj.d -o CMakeFiles/afr_crypto.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj -c C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c:31:8: error: unknown type name '_lock_t'
static _lock_t mpi_lock;
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c: In function 'esp_mpi_enable_hardware_hw_op':
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c:44:5: error: implicit declaration of function '_lock_acquire' [-Werror=implicit-function-declaration]
_lock_acquire(&mpi_lock);
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c: In function 'esp_mpi_disable_hardware_hw_op':
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c:62:5: error: implicit declaration of function '_lock_release'; did you mean '__sync_lock_release'? [-Werror=implicit-function-declaration]
_lock_release(&mpi_lock);
__sync_lock_release
cc1.exe: some warnings being treated as errors
[5/1651] Building C object CMakeFiles/afr_pkcs11_implement...endors/espressif/boards/ports/pkcs11/core_pkcs11_pal.c.obj
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/boards/ports/pkcs11/core_pkcs11_pal.c: In function 'PKCS11_PAL_FindObject':
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/boards/ports/pkcs11/core_pkcs11_pal.c:233:17: warning: unused variable 'pxZeroedData' [-Wunused-variable]
CK_BYTE_PTR pxZeroedData = NULL;
[8/1651] Building C object CMakeFiles/afr_tls.dir/vendors/espressif/esp-idf/components/mbedtls/port/mbedtls_debug.c.obj
In file included from C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/mbedtls/include/mbedtls/platform_time.h:77,
from C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/3rdparty/mbedtls/include/mbedtls/platform.h:68,
from C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/mbedtls_debug.c:18:
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/newlib/platform_include/time.h:25: warning: "CLOCK_MONOTONIC" redefined
#define CLOCK_MONOTONIC (clockid_t)4
In file included from C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/newlib/platform_include/time.h:22,
c:\users\rhonakam\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\xtensa-esp32-elf\sys-include\time.h:293: note: this is the location of the previous definition
#define CLOCK_MONOTONIC ((clockid_t) 4)
C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/vendors/espressif/esp-idf/components/newlib/platform_include/time.h:26: warning: "CLOCK_BOOTTIME" redefined
#define CLOCK_BOOTTIME (clockid_t)4
c:\users\rhonakam\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\xtensa-esp32-elf\sys-include\time.h:303: note: this is the location of the previous definition
#define CLOCK_BOOTTIME ((clockid_t) 7)
[9/1651] Building C object CMakeFiles/afr_tls.dir/libraries/freertos_plus/standard/tls/src/iot_tls.c.obj
from C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/freertos_plus/standard/tls/src/iot_tls.c:39:
[10/1651] Building C object CMakeFiles/afr_pkcs11_implemen...rePKCS11/source/portable/mbedtls/core_pkcs11_mbedtls.c.obj
from C:/gau/AWS/ESP32/freertos-1643010662146/FreeRTOS/libraries/abstractions/pkcs11/corePKCS11/source/portable/mbedtls/core_pkcs11_mbedtls.c:46:
[11/1651] Building C object CMakeFiles/afr_tls.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp_bignum.c.obj
Please suggets how to resolve
Users browsing this forum: Semrush [Bot] and 5 guests
