How do I use extram_bss in CMakeLists?
jsam589
Postby jsam589 » Wed Feb 02, 2022 11:37 pm
The API guide for external RAM mentions that extram_bss "linker fragment scheme" can be used to force all bss of a component into external RAM. Can someone show the code syntax to use this technique? I am on 4.0 and 4.4 IDFs using cmake.
Here is an example CMakeLists.txt for one of my application components:
set(srcs "ca_wifi.c" "wifi_scan.c" "ble_init.c" "gatt_svr.c")
idf_component_register(SRCS "${srcs}"
            INCLUDE_DIRS "." "../../main/include"
            "../bme680/include"
            "../ca_drivers/include" "../ca_sound/include"
            "../mqtt/include" "../partition_mgt/include"
            REQUIRES spiffs fatfs bt nvs_flash app_update esp-tls
            esp_adc_cal port mqtt)
franzhoepfinger
Re: How do I use extram_bss in CMakeLists?
Postby franzhoepfinger » Sun Apr 03, 2022 11:03 am
seem to be a Typo in Wiki.
.ext_ram.bss
seem to be the right one.
EXT_RAM_ATTR definition points to _SECTION_ATTR_IMPL(".ext_ram.bss", __COUNTER__)
matsumoto
Postby matsumoto » Thu Aug 29, 2024 2:24 pm
you have to create a linker fragment file and tell CMake where it is within your CMakeLists.txt.
See ESP-IDF API - Linker Script Generation. There you can also read about the different schemes and how to create your own.
See also ESP-IDF/components/esp_system/app.lf for the "default" scheme, which is used for all archives (components) and object files (source files) by default.
Best regards.
Users browsing this forum: Amazon [Bot], Qwantbot, Semrush [Bot] and 1 guest
