ESPRFTestTool Implementation Details
@ndr&zo
Postby @ndr&zo » Sun Feb 13, 2022 4:35 am
I'm trying to use the ESPRFTestTool to get some metrics of the channel between two ESP32. When using the TX packet in Wi-Fi Test mode, does anyone know how many packets per second are transmitted for each duty cycle? Besides, taking a look at the documentation, in the RX packet example, it is said that:
"• Correct: 996 means the total number of received packets.
• Desired: 996 indicates the number of received packets at a specifically set data rate."
Does anyone know what means "at a specifically set data rate"? The data rate is already set on another parameter. And in my measurements, the desired number is always lower than the correct number of packets. I would expect the "Desired" number to mean packets being received with errors, but this description of the Desired parameter is very unclear to me.
Also, it would be very nice to know what is the meaning of the parameters gain, para1, para2, and freq.
Thanks in advance for any help.
Users browsing this forum: Baidu [Spider], Google [Bot] and 3 guests
