GPIO 13 not functional with WiFi
streetec
Postby streetec » Mon Feb 14, 2022 9:35 am
I have an issue regarding the usage of GPIO13 and WiFi.
Reading the docs, the only restriction regarding WiFi and GPIO 13 I could find was the usage of ADC2 and WiFi at the same time is not possible.
I now have the issue, that I cannot use GPIO13 as an digital output when using WiFi.
I've got an SPI Display hooked up with its reset pin to GPIO13. When I do not include any WiFi library functions, my display and everything around it is working great! As soon as I include WiFi.h and use a funtion (like WiFi.softAP() or so) D13 does not reset the display anymore (Even when I call WiFi.mode(WIFI_OFF)).
I also tryed not using the WiFi library but coding it "by hand" from the esp_wifi.h header, same issue persists.
Can somebody explain this behavior?
Users browsing this forum: Semrush [Bot] and 1 guest
