ArtnetWifiFastLed troubles
Daedal
Postby Daedal » Wed Feb 16, 2022 8:19 pm
I am trying to use the ArtNetWiFiFastLed example to no avail. I have hooked up a strip of 51 LEDs to a sparkfun esp32 thing plus.
using the following code, i can connect to and see the esp32 from the router's connection table, but it doesn't seem to be receiving data. am i missing something obvious?
When powering up, we get a connected state and the serial monitor reports back the IP. I can see it has connected via checking the routers table. A moment or two after connection, the leds all flash Red, then Green, then Blue. So the initTest appears to work.
This lends me to believe that i'm failing on the software portion. I have tried using Resolume and Jinx separately to no avail. ( I tried both the aforementioned IP address and broadcast mode) .
I've tried Sparkfun's artnet dmx resources, failed at that, so am scaling back trying to find a simple example to test the artnet broadcast over wifi.
any and all helpful assistance is graciously appreciated.
This example will receive multiple universes via Art-Net and control a strip of
WS2812 LEDs via the FastLED library: https://github.com/FastLED/FastLED
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <ArtnetWifi.h>
#include <Arduino.h>
#include <FastLED.h>
// Wifi settings
const char* ssid = "MYWIFIHERE";
const char* password = "MYVOICEISMYPASSWORD";
// LED settings
const int numLeds = 51; // CHANGE FOR YOUR SETUP
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 12;
CRGB leds[numLeds];
// Art-Net settings
ArtnetWifi artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// connect to wifi – returns true if successful or false if not
boolean ConnectWifi(void)
  boolean state = true;
  int i = 0;
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("Connecting to WiFi");
  // Wait for connection
  Serial.print("Connecting");
    delay(500);
    Serial.print(".");
    if (i > 20){
      state = false;
    i++;
  if (state){
    Serial.println("");
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
    Serial.println("");
    Serial.println("Connection failed.");
  return state;
void initTest()
  for (int i = 0 ; i < numLeds ; i++) {
    leds[i] = CRGB(127, 0, 0);
  FastLED.show();
  delay(500);
    leds[i] = CRGB(0, 127, 0);
  FastLED.show();
  delay(500);
    leds[i] = CRGB(0, 0, 127);
  FastLED.show();
  delay(500);
    leds[i] = CRGB(0, 0, 0);
  FastLED.show();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
  sendFrame = 1;
  // set brightness of the whole strip
  if (universe == 15)
    FastLED.setBrightness(data[0]);
    FastLED.show();
  // Store which universe has got in
  if ((universe - startUniverse) < maxUniverses) {
    universesReceived[universe - startUniverse] = 1;
  for (int i = 0 ; i < maxUniverses ; i++)
    if (universesReceived[i] == 0)
      //Serial.println("Broke");
      sendFrame = 0;
  // read universe and put into the right part of the display buffer
  for (int i = 0; i < length / 3; i++)
    int led = i + (universe - startUniverse) * (previousDataLength / 3);
    if (led < numLeds)
      leds[led] = CRGB(data[i * 3], data[i * 3 + 1], data[i * 3 + 2]);
  previousDataLength = length;
  if (sendFrame)
    FastLED.show();
    // Reset universeReceived to 0
    memset(universesReceived, 0, maxUniverses);
void setup()
  ConnectWifi();
  artnet.begin();
  FastLED.addLeds<WS2812, dataPin, GRB>(leds, numLeds);
  initTest();
  // this will be called for each packet received
  artnet.setArtDmxCallback(onDmxFrame);
void loop()
  // we call the read function inside the loop
  artnet.read();
luminate
Re: ArtnetWifiFastLed troubles
Postby luminate » Fri Oct 21, 2022 11:32 am
Did you make any progress with this? I am in a similar position, using an ESP32 Dev Board, having tried various Artnet example scripts I am unable to receive any data from either Resolume or Jinx!
Users browsing this forum: Bing [Bot] and 3 guests
