esp32 buifi案例问题
Moderator: Bob
lgpww123
esp32 buifi案例问题
Postby lgpww123 » Sat Mar 05, 2022 3:54 pm
使用4.3编译案例BLUFI ,烧录芯片esp32 s3中,总是不停的复位“phy_init: failed to load RF calibration data (0xffffffff), falling back to full calibration”,使用4.4 编译器blufi 案例,烧录到esp32 s3 中,不会复位,可以正常搜索到蓝牙,但无法连接到wifi 也无法看到wifi
LJY
Re: esp32 buifi案例问题
Postby LJY » Tue May 10, 2022 7:41 am
esp32 s3 芯片,你需要使用 tag v4.4 及以上的版本.
具体是如何操作的呢?
这边试了一下,手机打开 EspBluFi APP, 先点击连接,然后点击配网,其中选择 station mode,输入要连接的 AP ssid 和 AP password, ESP32S3 就能连接上相应的 AP 了。 log 如下:
I (637) wifi:mode : sta (84:f7:03:80:00:78)
I (637) wifi:enable tsf
W (637) BT_INIT: esp_bt_controller_mem_release not implemented, return OK
I (637) BT_INIT: BT controller compile version [6881869]
I (647) BT_INIT: Bluetooth MAC: 84:f7:03:80:00:7a
I (667) BLUFI_EXAMPLE: BD ADDR: 84:f7:03:80:00:7a
I (667) BLUFI_EXAMPLE: BLUFI init finish
I (677) BLUFI_EXAMPLE: BLUFI VERSION 0102
I (12967) BLUFI_EXAMPLE: BLUFI ble connect
I (33817) BLUFI_EXAMPLE: BLUFI Set WIFI opmode 0
I (33817) wifi:mode : null
I (39127) BLUFI_EXAMPLE: BLUFI get wifi status from AP
I (82267) BLUFI_EXAMPLE: BLUFI Set WIFI opmode 1
I (82267) wifi:mode : sta (84:f7:03:80:00:78)
I (82267) wifi:enable tsf
I (82427) BLUFI_EXAMPLE: Recv STA SSID myssid
I (82467) BLUFI_EXAMPLE: Recv STA PASSWORD mypassword
I (82507) BLUFI_EXAMPLE: BLUFI requset wifi connect to AP
I (82557) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:6
I (83057) wifi:state: init -> auth (b0)
I (83167) wifi:state: auth -> assoc (0)
I (83217) wifi:state: assoc -> run (10)
I (83297) wifi:connected with myssid, aid = 1, channel 1, BW20, bssid = 70:af:6a:02:3c:22
I (83297) wifi:security: WPA2-PSK, phy: bgn, rssi: -33
I (83307) wifi:pm start, type: 1
I (83307) wifi:set rx beacon pti, rx_bcn_pti: 14, bcn_timeout: 14, mt_pti: 25000, mt_time: 10000
I (83317) wifi:BcnInt:102400, DTIM:1
I (85957) esp_netif_handlers: sta ip: 192.168.0.11, mask: 255.255.255.0, gw: 192.168.0.1
W (119187) wifi:<ba-add>idx:0 (ifx:0, 70:af:6a:02:3c:22), tid:0, ssn:4, winSize:64
