Error when creating littlefs partition image using littlefs_create_partition_image
lukecam95
Postby lukecam95 » Wed Mar 09, 2022 4:55 pm
Hi All,
I am trying to convert my the file system I use from spiffs to littlefs, however when I try to use the CMake function
littlefs_create_partition_image(partition_name path_to_folder_containing_files)
I run into the error below.
Please note that I can compile littlefs programs with no issues if I do not try to create a partition using the cmake command.
I have also installed MinGW with make and gcc as described in the documentation of mklittlefs.
I would greatly appreciate any help that you can give me.
Have a great day! :D
ESP-IDF version 4.4
Target device: ESP32
[558/1009] cmd.exe /C "cd /D C:\Users\kc\eclipse-workspace\littlefs_try1\components\esp_littlefs\mklittlefs && make dist"
FAILED: ../components/esp_littlefs/mklittlefs/mklittlefs
FIND: Parameter format not correct
'sed' is not recognized as an internal or external command,
operable program or batch file.
cc -std=gnu99 -Os -Wall -Itclap -Iinclude -Ilittlefs -I. -I ../src -D VERSION=\"0.2.3-40-ga14dabe\" -D LITTLEFS_VERSION=\"v2.4.1\" -D BUILD_CONFIG=\"\" -D BUILD_CONFIG_NAME=\"-generic\" -D __NO_INLINE__ -D LFS_NAME_MAX=32 -c -o ../src/littlefs/lfs.o ../src/littlefs/lfs.c
process_begin: CreateProcess(NULL, cc -std=gnu99 -Os -Wall -Itclap -Iinclude -Ilittlefs -I. -I ../src -D VERSION=\"0.2.3-40-ga14dabe\" -D LITTLEFS_VERSION=\"v2.4.1\" -D BUILD_CONFIG=\"\" -D BUILD_CONFIG_NAME=\"-generic\" -D __NO_INLINE__ -D LFS_NAME_MAX=32 -c -o ../src/littlefs/lfs.o ../src/littlefs/lfs.c, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [<builtin>: ../src/littlefs/lfs.o] Error 2
CMakeOutput.log
(70.3 KiB) Downloaded 457 times
console log.txt
(2.1 MiB) Downloaded 440 times
jeeper1974
Re: Error when creating littlefs partition image using littlefs_create_partition_image
Postby jeeper1974 » Sun Jul 10, 2022 7:44 am
I'm running into a similar issue. Did you ever get this working?
Roger
__len__
Postby __len__ » Mon Oct 03, 2022 9:42 am
I changed the C:\MinGW\bin\gcc.exe name to cc.exe,and it seems to work.
CKiamy
Postby CKiamy » Mon Jun 05, 2023 8:17 am
I have the same problem using the cmake command for littlefs. I would believe the problem rather has to do with the fact that the makefile is inside a git-submodule folder, and therefore cannot find the paths to the littlefs src folder, but I am not sure if it works this way...
Changing the name of the gcc executable seems like a rather "extreme" workaround imo. Have you, or anyone reading this, found another way to solve this problem?
CKiamy
Postby CKiamy » Mon Jun 05, 2023 9:57 am
Actually the problem has more to do with the fact that the makefile was intended to run on a POSIX system, which means it will not work for windows. There is a recent commit with an updated makefile that is supposed to work with windows:
https://github.com/BrianPugh/mklittlefs ... ix-windows
However this still does not work for me, in specific the line
Code: Untitled.make Select all
	FILES_TO_FORMAT := $(shell for /f "delims=" %%i in ('dir /s /b *.c *.cpp ^| findstr /v /i littlefs') do @echo %%i)
It still cannot find the source files.
Users browsing this forum: Bing [Bot], ChatGPT-User, PerplexityBot and 1 guest
