uart_set_baudrate sets incorrect baud rate
user91829
Postby user91829 » Mon Mar 21, 2022 9:27 pm
Code: Untitled.c Select all
    static QueueHandle_t uart0_queue;
uart_config_t uart_config = {
.baud_rate = 115200,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
// Install UART driver, and get the queue.
uart_driver_install(UART_NUM_1, 1024, 1024, 20, &uart0_queue, 0);
uart_param_config(UART_NUM_1, &uart_config);
vTaskDelay(100 / portTICK_RATE_MS);
uint32_t baudrate;
ESP_LOGI("MAIN", "BAUD RATE 0: %d", baudrate);
uart_get_baudrate(UART_NUM_1, &baudrate);
ESP_LOGI("MAIN", "BAUD RATE 1: %d", baudrate);
uart_set_baudrate(UART_NUM_1, 230400);
ESP_LOGI("MAIN", "BAUD RATE 2: %d", baudrate);
uart_set_baudrate(UART_NUM_1, 460800);
ESP_LOGI("MAIN", "BAUD RATE 3: %d", baudrate);
uart_set_baudrate(UART_NUM_1, 921600);
ESP_LOGI("MAIN", "BAUD RATE 4: %d", baudrate);
The above code gives the following output
I (857) MAIN: BAUD RATE 0: 0
I (857) MAIN: BAUD RATE 1: 115201
I (1057) MAIN: BAUD RATE 2: 230423
I (1257) MAIN: BAUD RATE 3: 460929
I (1457) MAIN: BAUD RATE 4: 922190
Am I doing something wrong here ?
I am using latest docker image `espressif/idf:release-v4.4` and this is the only code in `app_main()`
WiFive
Re: uart_set_baudrate sets incorrect baud rate
Postby WiFive » Mon Mar 21, 2022 10:46 pm
approximation is to be expected due to divider and clock frequency limitations
