Looking to restore Arduino to HUZZAH32 Feather
justinmreina
Contact:
Postby justinmreina » Fri Aug 11, 2017 6:50 pm
I have an Adafruit HUZZAH32 Feather which I have flashed clean with JTAG. I wanted to restore for Arduino use, how is this done?
I was thinking you can use the 'ESP32 DownloadTool' in the Espressif Flash Download Tool v3.4.8, is this possible?
f.h-f.s.
Re: Looking to restore Arduino to HUZZAH32 Feather
Postby f.h-f.s. » Fri Aug 11, 2017 9:07 pm
it is as simple as building and flashing with the arduino ide. No need for the download tool
justinmreina
Contact:
Postby justinmreina » Fri Aug 11, 2017 9:38 pm
My goodness, it was just that the speeds were too high.
Original: 921600/80MHz
Working: 115200/40MHz
Thanks for the input and the nudge, now I am back up and running! :)
kolban
Postby kolban » Fri Aug 11, 2017 11:23 pm
Speeds are interesting. I am running with 95% first time flash using 921600. I am using 12 inch USB cables between my ESP32s and a powered USB hub. Just an FYI.
f.h-f.s.
Postby f.h-f.s. » Sat Aug 12, 2017 7:10 am
it really depends on the board.
On my DOIT I can do 921600 when it's cold, when it is warm it fails 2 out of 3 times.
My Pycom lopy can handle 2m baud, 80mhz QIO flash. Hooked up on a 3m very old usb cable. And has never failed me.
Users browsing this forum: Google [Bot] and 4 guests
