I can not generate certificates for wpa2-enterprise and https-request.
It stay at "................+++" all the time when I use "openssl req -new -x509 -keyout wpa2_ca.key -out wpa2_ca.pem" command.
Thanks.
Openssl command do not work.
Re: Openssl command do not work.
What kind of machine is this? I have zero problems with this command on my Intel laptop with Debian GNU/Linux.
The system of my PC is Win7, 64 ultimate.What kind of machine is this? I have zero problems with this command on my Intel laptop with Debian GNU/Linux.
- $P@5~N1SV1J0XDI3VV}}$QW.png (1.75 KiB) Viewed 7272 times
My guess is that openssl needs a tty to prompt for further data. Can you try prefixing the command with 'winpty'? So 'winpty openssl req ...'
It works,but still have some problems.My guess is that openssl needs a tty to prompt for further data. Can you try prefixing the command with 'winpty'? So 'winpty openssl req ...'
I already have generated wpa2_ca.key,wpa2_ca.pem,wpa2_client.csr,wpa2_client.key
It goes wrong when I try to generate wpa2_client.crt
1.How can I get wpa2_server.key?
2.What is wrong when I try to generate generate wpa2_client.crt?
3.what is "ca1234" in openssl command?
Will somebody help me? Thans.
- L[()N{~929%S157_`WC%Z5A.png (17.6 KiB) Viewed 7240 times
- UW2YL`7ZXINJC8Y9~65K1BD.png (30.96 KiB) Viewed 7241 times
Users browsing this forum: Bytespider, Google [Bot] and 6 guests
