I am interfacing the ESP32 as an SPI master to external logic at 80 MHz. I need to know, on the ESP32's SPI master operating at 80 MHz, how much time passes between /CS going low and the first SCK rising edge? Is this parameter configurable?
Thanks for any help you can provide.
Zane
ESP32 SPI /CS setup time before first SCK pulse?
ZaneKaminski
ZaneKaminski
Re: ESP32 SPI /CS setup time before first SCK pulse?
Yes I have, but there is no relevant information. So presumably there is no configurable parameter for this but I nevertheless need to know the delay between /CS going low and the first SCK pulse.Did you check the docs?
Users browsing this forum: DuckDuckGo [Bot], Semrush [Bot] and 1 guest
