Waiting for download
bluebirdsoftware
Postby bluebirdsoftware » Tue Apr 26, 2022 8:04 am
I have built my own PCB for an ESP32 WROVER.
The PCB also has a reset button (from this url: https://www.espressif.com/sites/default ... eet_en.pdf)
But once in a few times (say 1 in 10 / 1 in 15 times) it doesn't restart but comes in the "waiting for download" mode.
I have connected GPIO_0 with a 10K resistor to 3.3v
What can be the problem?
rst:0x1 (POWERON_RESET),boot:0x0 (DOWNLOAD_BOOT(UART0/UART1/SDIO_FEI_FEO_V2))
username
Re: Waiting for download
Postby username » Wed Apr 27, 2022 2:17 am
Make sure you have a 0.1uf cap from EN to GND, and GPIO0 to GND. along with at least a 10k pullup to 3.3v for each pin.
bluebirdsoftware
Postby bluebirdsoftware » Thu Apr 28, 2022 7:30 am
I already have a 10K resistor between IO0 and 3.3v, a 10K resistor between EN and 3.3v and a 0.1uF capacitor between EN and GND.
It still sometimes boots into "download" mode.
chegewara
Postby chegewara » Thu Apr 28, 2022 7:33 am
To me it looks like hardware (soldering) issue. Looks at this log:
boot:0x0
It means all strapping pins are connected to GND. Unless it is what you need in your design.
PS how this line looks like when it works normally
bluebirdsoftware
Postby bluebirdsoftware » Thu Apr 28, 2022 7:52 am
The ESP32 Wrover is soldered by JLCPCB (so i hope they know how to solder).
This is my normal boot:
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
chegewara
Postby chegewara » Thu Apr 28, 2022 8:06 am
Yeap. As you can see here it is 0x33 now.
It looks like soldering issue or less likely faulty chip.
bluebirdsoftware
Postby bluebirdsoftware » Thu Apr 28, 2022 8:53 am
Okay, thank you. I will check if my other PCB's don't have this behaviour
username
Postby username » Thu Apr 28, 2022 12:06 pm
What about the 0.1uf cap on IO0 to GND ?
bluebirdsoftware
Postby bluebirdsoftware » Fri Apr 29, 2022 7:20 am
That is the only one i don't have. It could cause this problem?
username
Postby username » Fri Apr 29, 2022 11:52 am
I have found when I run into this issue on several other ESP32 kits/boards adding the cap to EN & IO0 solved the problem.
It can't hurt to just add it and try.
Users browsing this forum: Google [Bot], PerplexityBot and 3 guests
