ESP32-S2-MINI-1(U) is now NRND, but the datasheet for ESP32-S2-MINI-2(U) has not yet been released.
- Can we assume the pinout is the same for ESP32-S2-MINI-2(U) is the same as for 1(U)? Are there any substantial changes that can impact board layout?
- When will the datasheet be released?
Thank you.
ESP32-S2-MINI-2(U) changes / datasheet
Re: ESP32-S2-MINI-2(U) changes / datasheet
ESP32-S2-MINI-2(U) is pin to pin compatible with ESP32-S2-MINI-1(U), so changing modules will not impact the board's layout.
The release date for datasheet is to be determined. If you are in urgent need, please contact sales@espressif.com.
Hope this helps. Thank you!
By the way, you can also use https://www.espressif.com.cn/en/contact ... -questions to contact sales team for the datasheet.
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, DuckDuckGo [Bot] and 3 guests
