Hi!
I have a few ESP-IDF components (for example, the popular https://github.com/UncleRus/esp-idf-lib collection) and would like to upload them to the Espressif Component Registry. In this regard, there are a number of questions:
- Is there a detailed instruction for creating an idf_component.yml manifest and uploading components into the registry?
- How to get an API token for the registry?
- Which version of idf.py supports the "create-remote-component" command? idf.py from the ESP-IDF wizard does not support it.
Thank you.
Espressif component registry
ESP_kumekay
Re: Espressif component registry
Hi UncleRus,
As for the first 2 of your questions, we still looking for the best practices, so didn't open the registry public uploads yet. The best way now is to track the progress in this issue: https://github.com/espressif/idf-compon ... r/issues/4
As for `create-remote-component` it was only in some early alpha versions of the component manager and was removed later. Now it's enough to upload a version with `upload-component`, however, this is to be documented better.
Hi UncleRus,
Thank you for your interest in our Component Manager to upload your components. Your library is very impressive and for sure it will be a valuable contribution to the community!
If you don't mind, I will write you in private to discuss this collaboration.
Thanks for the kind words.
I will be happy to participate in the development of the component registry for the ESP-IDF.
ESP_Minatel, of course, let's talk privately. We can use private messages on this forum or you can write to my email: unclerus<at>gmail.com
mairswartz
Hello UncleRus,
Getting your library in the component registry would be truly amazing.
Thank you for your incredible work
check out my course https://learnesp32.com
Users browsing this forum: Amazon [Bot], ChatGPT-User and 3 guests
