ESP32 connecting to internet SIM800L problem
Doublementi
Postby Doublementi » Sat May 07, 2022 1:47 pm
Hi, i am trying to connect my SIM800L to internet but i have problem with initialization.
I'm using Wemos Lolin32 Lite.
I think that it doesn't dedect my SIM800L because Serial Output "Module : " Is empty, should be SIM 800L. Sim 800L is blinking every 3 seconds, and after some time is blinking each 0.5 seconds. Output says: Connecting to internet fail. I don't know what is going on, maybe i connected something incorrectly, could you please check what is wrong? In my project i want to send lat and lon values from neo6m to my firebase -> user -> exampleuser.
//Select your modem
//SSL/TLS is currently supported only with SIM8xx series
#define TINY_GSM_MODEM_SIM800
//Increase RX buffer
#define TINY_GSM_RX_BUFFER 256
//NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
#include <TinyGPSPlus.h> //https://github.com/mikalhart/TinyGPSPlus
#include <TinyGsmClient.h> //https://github.com/vshymanskyy/TinyGSM
#include <ArduinoHttpClient.h> //https://github.com/arduino-libraries/ArduinoHttpClient
const char FIREBASE_HOST[]  = "host"; //I want to connect to firebase user then change his lat/lon
const String FIREBASE_AUTH  = "auth";
const String USER_EMAIL ="email";
const String USER_PASSWORD = "pass";
const String USER_UID = "uid";
const String FIREBASE_PATH  = "x/x";
const int SSL_PORT          = 443;
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "internet";
char user[] = "";
char pass[] = "";
//GSM Module RX pin to ESP32 2
//GSM Module TX pin to ESP32 4
#define rxPin 4  //are these PIN's okay with my Lolin32 lite??
#define txPin 2
HardwareSerial sim800(1);
TinyGsm modem(sim800);
//GPS Module RX pin to ESP32 17
//GPS Module TX pin to ESP32 16
#define RXD2 16
#define TXD2 17
HardwareSerial neogps(2);
TinyGPSPlus gps;
//NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN
TinyGsmClientSecure gsm_client_secure_modem(modem, 0);
HttpClient http_client = HttpClient(gsm_client_secure_modem, FIREBASE_HOST, SSL_PORT);
unsigned long previousMillis = 0;
long interval = 10000;
  Serial.println("esp32 serial initialize");
  sim800.begin(9600, SERIAL_8N1, rxPin, txPin);
  Serial.println("SIM800L serial initialize");
  neogps.begin(9600, SERIAL_8N1, RXD2, TXD2);
  Serial.println("neogps serial initialize");
  delay(3000);
  //Restart takes quite some time
  //To skip it, call init() instead of restart()
  Serial.println("Initializing modem...");
  modem.restart();
  String modemInfo = modem.getModemInfo();
  Serial.print("Modem: ");
  Serial.println(modemInfo);  // not displaying
  // Unlock your SIM card with a PIN
  //modem.simUnlock("1234");
  http_client.setHttpResponseTimeout(90 * 1000); //^0 secs timeout
  //Serial.println("Initializing modem...");
  //modem.init();
  //String modemInfo = modem.getModemInfo();
  //Serial.print("Modem: ");
  //Serial.println(modemInfo);
  //Serial.print(F("Waiting for network..."));
  //if (!modem.waitForNetwork()) {
    //Serial.println(" fail");
    //delay(1000);
    //return;
  //Serial.println(" OK");
  Serial.print(F("Connecting to "));
  Serial.print(apn);
  if (!modem.gprsConnect(apn, user, pass)) {
    Serial.println(" fail");             // <- fail
    delay(1000);
    return;
  http_client.connect(FIREBASE_HOST, SSL_PORT);
  //MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
  while (true) {
    if (!http_client.connected()) {
      Serial.println();
      http_client.stop();// Shutdown
      Serial.println("HTTP  not connect");
    else{
      gps_loop();
void PostToFirebase(const char* method, const String & path , const String & data, HttpClient* http) {
  String response;
  int statusCode = 0;
  http->connectionKeepAlive(); // Currently, this is needed for HTTPS
  String url;
  if (path[0] != '/') {
    url = "/";
  url += path + ".json";
  url += "?auth=" + FIREBASE_AUTH;
  Serial.print("POST:");
  Serial.println(url);
  Serial.print("Data:");
  Serial.println(data);
  String contentType = "application/json";
  http->put(url, contentType, data);
  // read the status code and body of the response
  //statusCode-200 (OK) | statusCode -3 (TimeOut)
  statusCode = http->responseStatusCode();
  Serial.print("Status code: ");
  Serial.println(statusCode);
  response = http->responseBody();
  Serial.print("Response: ");
  Serial.println(response);
  if (!http->connected()) {
    Serial.println();
    http->stop();// Shutdown
    Serial.println("HTTP POST disconnected");
void gps_loop()
  //Can take up to 60 seconds
  boolean newData = false;
  for (unsigned long start = millis(); millis() - start < 2000;){
    while (neogps.available()){
      if (gps.encode(neogps.read())){
        newData = true;
  //If newData is true
  if(true){
  newData = false;
  String latitude, longitude;
  //float altitude;
  //unsigned long date, time, speed, satellites;
  latitude = String(gps.location.lat(), 6); // Latitude in degrees (double)
  longitude = String(gps.location.lng(), 6); // Longitude in degrees (double)
  //altitude = gps.altitude.meters(); // Altitude in meters (double)
  //date = gps.date.value(); // Raw date in DDMMYY format (u32)
  //time = gps.time.value(); // Raw time in HHMMSSCC format (u32)
  //speed = gps.speed.kmph();
  Serial.print("Latitude= ");
  Serial.print(latitude);
  Serial.print(" Longitude= ");
  Serial.println(longitude);
  String gpsData = "{";
  gpsData += "\"lat\":" + latitude + ",";
  gpsData += "\"lng\":" + longitude + "";
  gpsData += "}";
  //PUT   Write or replace data to a defined path, like messages/users/user1/<data>
  //PATCH   Update some of the keys for a defined path without replacing all of the data.
  //POST  Add to a list of data in our Firebase database. Every time we send a POST request, the Firebase client generates a unique key, like messages/users/<unique-id>/<data>
  //https://firebase.google.com/docs/database/rest/save-data
  PostToFirebase("PATCH", FIREBASE_PATH, gpsData, &http_client);
Wemos Lolin32 lite pinout
My sketch connection
Bez tytułu.png (730.03 KiB) Viewed 10500 times
Tradiot
Re: ESP32 connecting to internet SIM800L problem
Postby Tradiot » Sun May 08, 2022 8:35 am
Just a very quick observation..you have no shared ground wire from sim to esp. I use a bread board and put battery ground onto a rail, then have ground wire from rail to sim and a ground wire from rail to esp, you need this for signal reference
Tradiot
Postby Tradiot » Sun May 08, 2022 8:41 am
I forgot to mention, I have a minimum 1500k resistor in series on this ground wire to esp32
Doublementi
Postby Doublementi » Sun May 08, 2022 10:16 am
So i should connect the ground from esp32 to Sim800L and ground from battery to NEO6m?
Doublementi
Postby Doublementi » Sun May 08, 2022 10:28 am
You mean this?
without resistor.png (657.59 KiB) Viewed 10316 times
with resistor.png (658.31 KiB) Viewed 10316 times
Doublementi
Postby Doublementi » Sun May 08, 2022 12:09 pm
It works now, but i got lat 0 and lon 0
Doublementi
Postby Doublementi » Sun May 08, 2022 1:22 pm
My neo6m module is not available, any solution?
Doublementi
Postby Doublementi » Sun May 08, 2022 2:46 pm
Ok, it works perfectly, cold start - it took more than 20 minutes to start NEO6m
Tradiot
Postby Tradiot » Mon May 09, 2022 11:43 am
Can’t help with the gps, never used one
Squirrelbd
Postby Squirrelbd » Mon Feb 05, 2024 11:25 am
Check this out, not sure if it will help or not. Interfacing neo-6m GPS module.
Users browsing this forum: Baidu [Spider], Google [Bot], Qwantbot, YisouSpider and 2 guests
