Unable to get SHT35 working with web server.
T0T4LN00B
Postby T0T4LN00B » Thu May 12, 2022 4:08 pm
I use ESP32-Wrover-B and SHT35. I am trying to get it to display it's readings on web server. I get "Seeed_SHT35 does not name a type" error when I try to compile the code. What am I doing wrong?
Code: Untitled.txt Select all
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include <Arduino.h>
#include <Wire.h>
#include <Seeed_SHT35.h>
// Replace with your network credentials
const char* ssid = "MySSID";
const char* password = "MyPassword";
SHT35 sht35 = SHT35();
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readSHT35Temperature(){
float t = sht35.readTemperature();
if (! sht35.begin(0x44)) // Set to 0x45 for alternate i2c addr
Serial.println("SHT35 test");
while (1) delay(1);
if (isnan(t)) {
Serial.println("Failed to read temperature!");
return "--";
else {
Serial.print("");
Serial.print("Temperature: ");
Serial.println(t);
return String(t);
String readSHT35Humidity() {
float h = sht35.readHumidity();
if (isnan(h)) {
Serial.println("Failed to read Humidity!");
return "--";
else {
Serial.print("Humidity: ");
Serial.println(h);
Serial.println("");
return String(h);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<style>
html {
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 3.0rem; }
.units { font-size: 1.2rem; }
.sht35-labels{
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>ESP32 SHT35 Web Server</h2>
<p>
<i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
<span class="sht35-labels">Temperature</span>
<span id="temperature">%TEMPERATURE%</span>
<sup class="units">&deg;C</sup>
</p>
<p>
<i class="fas fa-tint" style="color:#00add6;"></i>
<span class="sht35-labels">Humidity</span>
<span id="humidity">%HUMIDITY%</span>
<sup class="units">%</sup>
</p>
</body>
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperature").innerHTML = this.responseText;
xhttp.open("GET", "/temperature", true);
xhttp.send();
}, 10000 ) ;
document.getElementById("humidity").innerHTML = this.responseText;
xhttp.open("GET", "/humidity", true);
xhttp.send();
}, 10000 ) ;
</script>
</html>)rawliteral";
// Replaces placeholder with sht35 values
String processor(const String& var){
//Serial.println(var);
if(var == "TEMPERATURE"){
return readSHT35Temperature();
else if(var == "HUMIDITY"){
return readSHT35Humidity();
return String();
void setup(){
// Serial port for debugging purposes
// Connect to Wi-Fi
WiFi.begin(ssid, password);
delay(1000);
Serial.println("Connecting to WiFi..");
// Print ESP32 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readSHT35Temperature().c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readSHT35Humidity().c_str());
// Start server
server.begin();
void loop(){
Users browsing this forum: trendictionbot and 1 guest
