ESP32 not getting ip from router
shaqlain garana
Postby shaqlain garana » Fri May 13, 2022 10:20 am
3 out of time 5 time my esp not connects to specific SSID and gives following error.
This issue varies with board to board some only connects to other SSID while some connect with another SSID and wise versa.
I am using BluFI for network configuration Whule i can not share the entire code, here is the glimpse of my code.
static void initialise_wifi(void)
wifi_event_group = xEventGroupCreate();
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
assert(sta_netif);
ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &ip_event_handler, NULL));
esp_wifi_set_storage(WIFI_STORAGE_RAM);
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK( esp_wifi_start());
esp_err_t err = tcpip_adapter_dhcpc_start(TCPIP_ADAPTER_IF_STA);
if(err == ESP_ERR_TCPIP_ADAPTER_DHCPC_START_FAILED){
ESP_ERROR_CHECK(err);
char* Hostname = nameSet();
esp_err_t ret = esp_netif_set_hostname(sta_netif ,Hostname);
if(ret != ESP_OK ){
ESP_LOGE("WIFI","failed to set hostname:%d",ret);
//esp_netif_dhcpc_start(sta_netif);
case ESP_BLUFI_EVENT_GET_WIFI_STATUS: {
wifi_mode_t mode;
esp_blufi_extra_info_t info;
esp_wifi_get_mode(&mode);
if (gl_sta_connected) {
memset(&info, 0, sizeof(esp_blufi_extra_info_t));
memcpy(info.sta_bssid, gl_sta_bssid, 6);
info.sta_bssid_set = false;
info.sta_ssid = gl_sta_ssid;
info.sta_ssid_len = gl_sta_ssid_len;
esp_blufi_send_wifi_conn_report(mode, ESP_BLUFI_STA_CONN_SUCCESS, 0, &info); // add device type
esp_blufi_send_wifi_conn_report(mode, ESP_BLUFI_STA_CONN_FAIL, 0, NULL);
BLUFI_INFO("BLUFI get wifi status from AP\n");
case ESP_BLUFI_EVENT_RECV_SLAVE_DISCONNECT_BLE:
vTaskSuspend(blink_taskHandler);
BLUFI_INFO("blufi close a gatt connection");
esp_blufi_disconnect();
esp_restart();
case ESP_BLUFI_EVENT_DEAUTHENTICATE_STA:
/* TODO */
case ESP_BLUFI_EVENT_RECV_STA_BSSID:
// my code here
//memcpy(sta_config.sta.bssid, param->sta_bssid.bssid, 6);
//sta_config.sta.bssid_set = 0;
//fileWrite(WIFI_BSSID_PATH,(char *)sta_config.sta.bssid);
//esp_wifi_set_config(WIFI_IF_STA, &sta_config);
//BLUFI_INFO("Recv STA BSSID %s\n", sta_config.sta.ssid);
case ESP_BLUFI_EVENT_RECV_STA_SSID:
strncpy((char *)sta_config.sta.ssid, (char *)param->sta_ssid.ssid, param->sta_ssid.ssid_len);
sta_config.sta.ssid[param->sta_ssid.ssid_len] = '\0';
fileWrite(WIFI_SSID_PATH,(char *)sta_config.sta.ssid);
sta_config.sta.scan_method = WIFI_ALL_CHANNEL_SCAN;
//sta_config.sta.threshold.authmode = WIFI_AUTH_WPA_WPA2_PSK;
//sta_config.sta.threshold.rssi = 0;
// sta_config.sta.threshold.authmode = 0;
//sta_config.sta.listen_interval = 10000;
sta_config.sta.bssid_set = false;
// sta_config.sta.sort_method = 1;
//sta_config.sta.channel = 0;
sta_config.sta.pmf_cfg.capable = true;
sta_config.sta.pmf_cfg.required = false;
// esp_wifi_set_config(WIFI_IF_STA, &sta_config);
BLUFI_INFO("Recv STA SSID %s\n", sta_config.sta.ssid);
case ESP_BLUFI_EVENT_RECV_STA_PASSWD:
// my code here
strncpy((char *)sta_config.sta.password, (char *)param->sta_passwd.passwd, param->sta_passwd.passwd_len);
sta_config.sta.password[param->sta_passwd.passwd_len] = '\0';
sta_config.sta.threshold.authmode = WIFI_AUTH_WPA_PSK;
//sta_config.sta.listen_interval = 0;
//sta_config.sta.sort_method = 1;
fileWrite(WIFI_PASSWORD_PATH,(char *)sta_config.sta.password);
esp_wifi_start();
BLUFI_INFO("Recv STA PASSWORD %s\n", sta_config.sta.password);
here are the logs.
I (66927) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (66927) wifi:state: init -> auth (b0)
I (67047) TOUCH: cmd value is 1
I (67297) TOUCH: cmd value is 1
I (67927) wifi:state: auth -> init (200)
I (67927) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (67937) WiFi: retry to connect to the AP : 43
I (69987) WiFi: retry to connect to the AP : 44
I (69997) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (69997) wifi:state: init -> auth (b0)
I (70547) TOUCH: cmd value is 1
I (71007) wifi:state: auth -> init (200)
I (71007) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (71007) WiFi: retry to connect to the AP : 45
I (73057) WiFi: retry to connect to the AP : 46
I (73067) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (73077) wifi:state: init -> auth (b0)
I (74047) TOUCH: cmd value is 1
I (74077) wifi:state: auth -> init (200)
I (74077) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (74077) WiFi: retry to connect to the AP : 47
I (74297) TOUCH: cmd value is 1
I (76127) WiFi: retry to connect to the AP : 48
I (76147) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (76147) wifi:state: init -> auth (b0)
E (76617) esp-tls: couldn't get hostname for :mqtt.whitelion.in: getaddrinfo() returns 202, addrinfo=0x0
E (76617) TRANSPORT_BASE: Failed to open a new connection: 32769
E (76617) MQTT_CLIENT: Error transport connect
I (76627) MQTT: MQTT_EVENT_ERROR
E (76627) MQTT: Last error reported from esp-tls: 0x8001
I (76637) MQTT: Last errno string (Success)
I (76637) MQTT: MQTT_EVENT_DISCONNECTED
I (77147) wifi:state: auth -> init (200)
I (77147) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (77157) WiFi: retry to connect to the AP : 49
I (77547) TOUCH: cmd value is 1
I (77797) TOUCH: cmd value is 1
I (79207) WiFi: retry to connect to the AP : 50
I (79217) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (79217) wifi:state: init -> auth (b0)
I (80217) wifi:state: auth -> init (200)
I (80217) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (80227) WiFi: retry to connect to the AP : 51
I (81047) TOUCH: cmd value is 1
I (81297) TOUCH: cmd value is 1
I (82277) WiFi: retry to connect to the AP : 52
I (82287) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (82287) wifi:state: init -> auth (b0)
I (83287) wifi:state: auth -> init (200)
I (83287) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (83297) WiFi: retry to connect to the AP : 53
I (84547) TOUCH: cmd value is 1
I (84797) TOUCH: cmd value is 1
I (85347) WiFi: retry to connect to the AP : 54
I (85357) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (85357) wifi:state: init -> auth (b0)
I (86367) wifi:state: auth -> init (200)
I (86367) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (86367) WiFi: retry to connect to the AP : 55
E (86647) esp-tls: couldn't get hostname for :mqtt.whitelion.in: getaddrinfo() returns 202, addrinfo=0x0
E (86647) TRANSPORT_BASE: Failed to open a new connection: 32769
E (86647) MQTT_CLIENT: Error transport connect
I (86657) MQTT: MQTT_EVENT_ERROR
E (86657) MQTT: Last error reported from esp-tls: 0x8001
I (86667) MQTT: Last errno string (Success)
I (86667) MQTT: MQTT_EVENT_DISCONNECTED
I (88047) TOUCH: cmd value is 1
I (88297) TOUCH: cmd value is 1
I (88417) WiFi: retry to connect to the AP : 56
I (88427) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (88437) wifi:state: init -> auth (b0)
I (89437) wifi:state: auth -> init (200)
I (89437) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (89437) WiFi: retry to connect to the AP : 57
I (91487) WiFi: retry to connect to the AP : 58
I (91507) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (91507) wifi:state: init -> auth (b0)
I (91547) TOUCH: cmd value is 1
I (92507) wifi:state: auth -> init (200)
I (92507) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (92517) WiFi: retry to connect to the AP : 59
I (94567) WiFi: retry to connect to the AP : 60
I (94577) wifi:new:<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (94577) wifi:state: init -> auth (b0)
I (95047) TOUCH: cmd value is 1
I (95297) TOUCH: cmd value is 1
I (95577) wifi:state: auth -> init (200)
I (95577) wifi:new:<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
I (95587) wifi:flush txq
Here is the configuration setting
[Codebox]#
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET_ARCH_XTENSA=y
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# SDK tool configuration
CONFIG_SDK_TOOLPREFIX="xtensa-esp32-elf-"
# CONFIG_SDK_TOOLCHAIN_SUPPORTS_TIME_WIDE_64_BITS is not set
# end of SDK tool configuration
# Build type
CONFIG_APP_BUILD_TYPE_APP_2NDBOOT=y
# CONFIG_APP_BUILD_TYPE_ELF_RAM is not set
CONFIG_APP_BUILD_GENERATE_BINARIES=y
CONFIG_APP_BUILD_BOOTLOADER=y
CONFIG_APP_BUILD_USE_FLASH_SECTIONS=y
# end of Build type
# Application manager
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
# CONFIG_APP_PROJECT_VER_FROM_CONFIG is not set
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
# end of Application manager
# Bootloader config
CONFIG_BOOTLOADER_OFFSET_IN_FLASH=0x1000
CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_DEBUG is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_BOOTLOADER_LOG_LEVEL_NONE=y
# CONFIG_BOOTLOADER_LOG_LEVEL_ERROR is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_WARN is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_INFO is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_DEBUG is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE is not set
CONFIG_BOOTLOADER_LOG_LEVEL=0
# CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_8V is not set
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
# CONFIG_BOOTLOADER_WDT_ENABLE is not set
# CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_IN_DEEP_SLEEP is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_ON_POWER_ON is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_ALWAYS is not set
CONFIG_BOOTLOADER_RESERVE_RTC_SIZE=0
# CONFIG_BOOTLOADER_CUSTOM_RESERVE_RTC is not set
CONFIG_BOOTLOADER_FLASH_XMC_SUPPORT=y
# end of Bootloader config
# Security features
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT is not set
# CONFIG_SECURE_FLASH_ENC_ENABLED is not set
# end of Security features
# Serial flasher config
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
# CONFIG_ESPTOOLPY_NO_STUB is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR=y
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_80M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_40M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="40m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="4MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_ESPTOOLPY_MONITOR_BAUD_CONSOLE=y
# CONFIG_ESPTOOLPY_MONITOR_BAUD_9600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_57600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_115200B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_230400B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_921600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_2MB is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
# Partition Table
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_SINGLE_APP_LARGE is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
# Compiler options
# CONFIG_COMPILER_OPTIMIZATION_DEFAULT is not set
CONFIG_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL=2
# CONFIG_COMPILER_OPTIMIZATION_CHECKS_SILENT is not set
CONFIG_COMPILER_HIDE_PATHS_MACROS=y
CONFIG_COMPILER_CXX_EXCEPTIONS=y
CONFIG_COMPILER_CXX_EXCEPTIONS_EMG_POOL_SIZE=0
# CONFIG_COMPILER_CXX_RTTI is not set
CONFIG_COMPILER_STACK_CHECK_MODE_NONE=y
# CONFIG_COMPILER_STACK_CHECK_MODE_NORM is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_STRONG is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_ALL is not set
# CONFIG_COMPILER_WARN_WRITE_STRINGS is not set
# CONFIG_COMPILER_DISABLE_GCC8_WARNINGS is not set
# CONFIG_COMPILER_DUMP_RTL_FILES is not set
# end of Compiler options
# Component config
# Application Level Tracing
# CONFIG_APPTRACE_DEST_JTAG is not set
CONFIG_APPTRACE_DEST_NONE=y
CONFIG_APPTRACE_LOCK_ENABLE=y
# end of Application Level Tracing
# ESP-ASIO
# CONFIG_ASIO_SSL_SUPPORT is not set
# end of ESP-ASIO
# Bluetooth
CONFIG_BT_ENABLED=y
# Bluetooth controller
CONFIG_BTDM_CTRL_MODE_BLE_ONLY=y
# CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY is not set
# CONFIG_BTDM_CTRL_MODE_BTDM is not set
CONFIG_BTDM_CTRL_BLE_MAX_CONN=3
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CTRL_PCM_ROLE_EFF=0
CONFIG_BTDM_CTRL_PCM_POLAR_EFF=0
CONFIG_BTDM_CTRL_BLE_MAX_CONN_EFF=3
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CTRL_PINNED_TO_CORE_0=y
# CONFIG_BTDM_CTRL_PINNED_TO_CORE_1 is not set
CONFIG_BTDM_CTRL_PINNED_TO_CORE=0
CONFIG_BTDM_CTRL_HCI_MODE_VHCI=y
# CONFIG_BTDM_CTRL_HCI_MODE_UART_H4 is not set
# MODEM SLEEP Options
CONFIG_BTDM_CTRL_MODEM_SLEEP=y
CONFIG_BTDM_CTRL_MODEM_SLEEP_MODE_ORIG=y
# CONFIG_BTDM_CTRL_MODEM_SLEEP_MODE_EVED is not set
CONFIG_BTDM_CTRL_LPCLK_SEL_MAIN_XTAL=y
# end of MODEM SLEEP Options
CONFIG_BTDM_BLE_DEFAULT_SCA_250PPM=y
CONFIG_BTDM_BLE_SLEEP_CLOCK_ACCURACY_INDEX_EFF=1
CONFIG_BTDM_BLE_SCAN_DUPL=y
CONFIG_BTDM_SCAN_DUPL_TYPE_DEVICE=y
# CONFIG_BTDM_SCAN_DUPL_TYPE_DATA is not set
# CONFIG_BTDM_SCAN_DUPL_TYPE_DATA_DEVICE is not set
CONFIG_BTDM_SCAN_DUPL_TYPE=0
CONFIG_BTDM_SCAN_DUPL_CACHE_SIZE=200
# CONFIG_BTDM_BLE_MESH_SCAN_DUPL_EN is not set
CONFIG_BTDM_CTRL_FULL_SCAN_SUPPORTED=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_SUPP=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_NUM=100
CONFIG_BTDM_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
CONFIG_BTDM_RESERVE_DRAM=0xdb5c
CONFIG_BTDM_CTRL_HLI=y
# end of Bluetooth controller
CONFIG_BT_BLUEDROID_ENABLED=y
# CONFIG_BT_NIMBLE_ENABLED is not set
# CONFIG_BT_CONTROLLER_ONLY is not set
# Bluedroid Options
CONFIG_BT_BTC_TASK_STACK_SIZE=3072
CONFIG_BT_BLUEDROID_PINNED_TO_CORE_0=y
# CONFIG_BT_BLUEDROID_PINNED_TO_CORE_1 is not set
CONFIG_BT_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BT_BTU_TASK_STACK_SIZE=4096
# CONFIG_BT_BLUEDROID_MEM_DEBUG is not set
# CONFIG_BT_CLASSIC_ENABLED is not set
CONFIG_BT_BLE_ENABLED=y
CONFIG_BT_GATTS_ENABLE=y
# CONFIG_BT_GATTS_PPCP_CHAR_GAP is not set
CONFIG_BT_BLE_BLUFI_ENABLE=y
CONFIG_BT_GATT_MAX_SR_PROFILES=8
# CONFIG_BT_GATTS_SEND_SERVICE_CHANGE_MANUAL is not set
CONFIG_BT_GATTS_SEND_SERVICE_CHANGE_AUTO=y
CONFIG_BT_GATTS_SEND_SERVICE_CHANGE_MODE=0
# CONFIG_BT_GATTC_ENABLE is not set
# CONFIG_BT_BLE_SMP_ENABLE is not set
CONFIG_BT_STACK_NO_LOG=y
CONFIG_BT_ACL_CONNECTIONS=1
CONFIG_BT_MULTI_CONNECTION_ENBALE=y
# CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST is not set
# CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY is not set
# CONFIG_BT_BLE_HOST_QUEUE_CONG_CHECK is not set
# CONFIG_BT_BLE_ACT_SCAN_REP_ADV_SCAN is not set
CONFIG_BT_BLE_ESTAB_LINK_CONN_TOUT=30
# CONFIG_BT_BLE_RPA_SUPPORTED is not set
# end of Bluedroid Options
# end of Bluetooth
# CONFIG_BLE_MESH is not set
# CoAP Configuration
CONFIG_COAP_MBEDTLS_PSK=y
# CONFIG_COAP_MBEDTLS_PKI is not set
# CONFIG_COAP_MBEDTLS_DEBUG is not set
CONFIG_COAP_LOG_DEFAULT_LEVEL=0
# end of CoAP Configuration
# Driver configurations
# ADC configuration
CONFIG_ADC_FORCE_XPD_FSM=y
CONFIG_ADC_DISABLE_DAC=y
# end of ADC configuration
# MCPWM configuration
# CONFIG_MCPWM_ISR_IN_IRAM is not set
# end of MCPWM configuration
# SPI configuration
# CONFIG_SPI_MASTER_IN_IRAM is not set
# CONFIG_SPI_MASTER_ISR_IN_IRAM is not set
# CONFIG_SPI_SLAVE_IN_IRAM is not set
# CONFIG_SPI_SLAVE_ISR_IN_IRAM is not set
# end of SPI configuration
# TWAI configuration
# CONFIG_TWAI_ISR_IN_IRAM is not set
# CONFIG_TWAI_ERRATA_FIX_BUS_OFF_REC is not set
# CONFIG_TWAI_ERRATA_FIX_TX_INTR_LOST is not set
# CONFIG_TWAI_ERRATA_FIX_RX_FRAME_INVALID is not set
# CONFIG_TWAI_ERRATA_FIX_RX_FIFO_CORRUPT is not set
# end of TWAI configuration
# UART configuration
CONFIG_UART_ISR_IN_IRAM=y
# end of UART configuration
# RTCIO configuration
# CONFIG_RTCIO_SUPPORT_RTC_GPIO_DESC is not set
# end of RTCIO configuration
# GPIO Configuration
# CONFIG_GPIO_ESP32_SUPPORT_SWITCH_SLP_PULL is not set
# end of GPIO Configuration
# GDMA Configuration
# CONFIG_GDMA_CTRL_FUNC_IN_IRAM is not set
# CONFIG_GDMA_ISR_IRAM_SAFE is not set
# end of GDMA Configuration
# end of Driver configurations
# eFuse Bit Manager
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE is not set
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT is not set
CONFIG_EFUSE_MAX_BLK_LEN=192
# end of eFuse Bit Manager
# ESP-TLS
CONFIG_ESP_TLS_USING_MBEDTLS=y
# CONFIG_ESP_TLS_USE_SECURE_ELEMENT is not set
# CONFIG_ESP_TLS_SERVER is not set
# CONFIG_ESP_TLS_CLIENT_SESSION_TICKETS is not set
# CONFIG_ESP_TLS_PSK_VERIFICATION is not set
# CONFIG_ESP_TLS_INSECURE is not set
# end of ESP-TLS
# ESP32-specific
CONFIG_ESP32_REV_MIN_0=y
# CONFIG_ESP32_REV_MIN_1 is not set
# CONFIG_ESP32_REV_MIN_2 is not set
# CONFIG_ESP32_REV_MIN_3 is not set
CONFIG_ESP32_REV_MIN=0
CONFIG_ESP32_DPORT_WORKAROUND=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_240 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=160
# CONFIG_ESP32_SPIRAM_SUPPORT is not set
# CONFIG_ESP32_TRAX is not set
CONFIG_ESP32_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ESP32_ULP_COPROC_ENABLED is not set
CONFIG_ESP32_ULP_COPROC_RESERVE_MEM=0
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_ESP32_BROWNOUT_DET=y
CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_ESP32_BROWNOUT_DET_LVL=0
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y
# CONFIG_ESP32_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_ESP32_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_ESP32_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=y
# CONFIG_ESP32_XTAL_FREQ_26 is not set
# CONFIG_ESP32_XTAL_FREQ_AUTO is not set
CONFIG_ESP32_XTAL_FREQ=40
# CONFIG_ESP32_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V3_1_BOOTLOADERS is not set
# CONFIG_ESP32_USE_FIXED_STATIC_RAM_SIZE is not set
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
# end of ESP32-specific
# Ethernet
CONFIG_ETH_ENABLED=y
CONFIG_ETH_USE_ESP32_EMAC=y
CONFIG_ETH_PHY_INTERFACE_RMII=y
CONFIG_ETH_RMII_CLK_INPUT=y
# CONFIG_ETH_RMII_CLK_OUTPUT is not set
CONFIG_ETH_RMII_CLK_IN_GPIO=0
CONFIG_ETH_DMA_BUFFER_SIZE=512
CONFIG_ETH_DMA_RX_BUFFER_NUM=10
CONFIG_ETH_DMA_TX_BUFFER_NUM=10
CONFIG_ETH_USE_SPI_ETHERNET=y
# CONFIG_ETH_SPI_ETHERNET_DM9051 is not set
# CONFIG_ETH_SPI_ETHERNET_W5500 is not set
# CONFIG_ETH_SPI_ETHERNET_KSZ8851SNL is not set
# CONFIG_ETH_USE_OPENETH is not set
# end of Ethernet
# Event Loop Library
# CONFIG_ESP_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
# end of Event Loop Library
# GDB Stub
# end of GDB Stub
# MAC Config
CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_STA=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_AP=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_BT=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_ETH=y
# CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_TWO is not set
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES=4
# end of MAC Config
# Sleep Config
CONFIG_ESP_SLEEP_POWER_DOWN_FLASH=y
CONFIG_ESP_SLEEP_RTC_BUS_ISO_WORKAROUND=y
# CONFIG_ESP_SLEEP_GPIO_RESET_WORKAROUND is not set
# CONFIG_ESP_SLEEP_FLASH_LEAKAGE_WORKAROUND is not set
# end of Sleep Config
# end of Hardware Settings
# IPC (Inter-Processor Call)
CONFIG_ESP_IPC_TASK_STACK_SIZE=1536
CONFIG_ESP_IPC_USES_CALLERS_PRIORITY=y
CONFIG_ESP_IPC_ISR_ENABLE=y
# end of IPC (Inter-Processor Call)
# ESP NETIF Adapter
CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_ESP_NETIF_TCPIP_LWIP=y
# CONFIG_ESP_NETIF_LOOPBACK is not set
CONFIG_ESP_NETIF_TCPIP_ADAPTER_COMPATIBLE_LAYER=y
# end of ESP NETIF Adapter
# PHY
CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP_PHY_MAX_TX_POWER=20
CONFIG_ESP_PHY_REDUCE_TX_POWER=y
# end of PHY
# Power Management
# CONFIG_PM_ENABLE is not set
# end of Power Management
# ESP System Settings
# CONFIG_ESP_SYSTEM_PANIC_PRINT_HALT is not set
CONFIG_ESP_SYSTEM_PANIC_PRINT_REBOOT=y
# CONFIG_ESP_SYSTEM_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP_SYSTEM_PANIC_GDBSTUB is not set
# CONFIG_ESP_SYSTEM_GDBSTUB_RUNTIME is not set
# Memory protection
# end of Memory protection
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_ESP_MAIN_TASK_STACK_SIZE=3584
CONFIG_ESP_MAIN_TASK_AFFINITY_CPU0=y
# CONFIG_ESP_MAIN_TASK_AFFINITY_CPU1 is not set
# CONFIG_ESP_MAIN_TASK_AFFINITY_NO_AFFINITY is not set
CONFIG_ESP_MAIN_TASK_AFFINITY=0x0
CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE=2048
CONFIG_ESP_CONSOLE_UART_DEFAULT=y
# CONFIG_ESP_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_NONE is not set
CONFIG_ESP_CONSOLE_UART=y
CONFIG_ESP_CONSOLE_MULTIPLE_UART=y
CONFIG_ESP_CONSOLE_UART_NUM=0
CONFIG_ESP_CONSOLE_UART_BAUDRATE=115200
CONFIG_ESP_INT_WDT=y
CONFIG_ESP_INT_WDT_TIMEOUT_MS=300
CONFIG_ESP_INT_WDT_CHECK_CPU1=y
CONFIG_ESP_TASK_WDT=y
# CONFIG_ESP_TASK_WDT_PANIC is not set
CONFIG_ESP_TASK_WDT_TIMEOUT_S=5
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
# CONFIG_ESP_PANIC_HANDLER_IRAM is not set
CONFIG_ESP_SYSTEM_CHECK_INT_LEVEL_5=y
# end of ESP System Settings
# Wi-Fi
CONFIG_ESP32_WIFI_ENABLED=y
CONFIG_ESP32_WIFI_SW_COEXIST_ENABLE=y
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=64
# CONFIG_ESP32_WIFI_STATIC_TX_BUFFER is not set
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
# CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1 is not set
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
CONFIG_ESP32_WIFI_IRAM_OPT=y
CONFIG_ESP32_WIFI_RX_IRAM_OPT=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE=y
# CONFIG_ESP_WIFI_SLP_IRAM_OPT is not set
CONFIG_ESP_WIFI_STA_DISCONNECTED_PM_ENABLE=y
# CONFIG_ESP_WIFI_GMAC_SUPPORT is not set
CONFIG_ESP_WIFI_SOFTAP_SUPPORT=y
# end of Wi-Fi
# Core dump
# CONFIG_ESP_COREDUMP_ENABLE_TO_FLASH is not set
# CONFIG_ESP_COREDUMP_ENABLE_TO_UART is not set
CONFIG_ESP_COREDUMP_ENABLE_TO_NONE=y
# end of Core dump
# FAT Filesystem support
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
# CONFIG_FATFS_USE_FASTSEEK is not set
# end of FAT Filesystem support
# FreeRTOS
# CONFIG_FREERTOS_UNICORE is not set
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_TICK_SUPPORT_CORETIMER=y
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_SYSTICK_USES_CCOUNT=y
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
# CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE is not set
# CONFIG_FREERTOS_ASSERT_DISABLE is not set
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
CONFIG_FREERTOS_ISR_STACKSIZE=1536
# CONFIG_FREERTOS_LEGACY_HOOKS is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_FREERTOS_ENABLE_STATIC_TASK_CLEAN_UP is not set
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2048
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
# CONFIG_FREERTOS_USE_TRACE_FACILITY is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
CONFIG_FREERTOS_PLACE_FUNCTIONS_INTO_FLASH=y
CONFIG_FREERTOS_DEBUG_OCDAWARE=y
# CONFIG_FREERTOS_FPU_IN_ISR is not set
# CONFIG_FREERTOS_ENABLE_TASK_SNAPSHOT is not set
# end of FreeRTOS
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=y
# CONFIG_HEAP_POISONING_LIGHT is not set
# CONFIG_HEAP_POISONING_COMPREHENSIVE is not set
CONFIG_HEAP_TRACING_OFF=y
# CONFIG_HEAP_TRACING_STANDALONE is not set
# CONFIG_HEAP_TRACING_TOHOST is not set
# CONFIG_HEAP_ABORT_WHEN_ALLOCATION_FAILS is not set
# end of Heap memory debugging
# Log output
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_MAXIMUM_EQUALS_DEFAULT=y
# CONFIG_LOG_MAXIMUM_LEVEL_DEBUG is not set
# CONFIG_LOG_MAXIMUM_LEVEL_VERBOSE is not set
CONFIG_LOG_MAXIMUM_LEVEL=3
CONFIG_LOG_COLORS=y
CONFIG_LOG_TIMESTAMP_SOURCE_RTOS=y
# CONFIG_LOG_TIMESTAMP_SOURCE_SYSTEM is not set
# end of Log output
# LWIP
CONFIG_LWIP_LOCAL_HOSTNAME="AirChip"
# CONFIG_LWIP_NETIF_API is not set
# CONFIG_LWIP_TCPIP_CORE_LOCKING is not set
CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES=y
# CONFIG_LWIP_L2_TO_L3_COPY is not set
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=10
# CONFIG_LWIP_USE_ONLY_LWIP_SELECT is not set
# CONFIG_LWIP_SO_LINGER is not set
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=y
# CONFIG_LWIP_NETBUF_RECVINFO is not set
CONFIG_LWIP_IP4_FRAG=y
CONFIG_LWIP_IP6_FRAG=y
CONFIG_LWIP_IP4_REASSEMBLY=y
# CONFIG_LWIP_IP6_REASSEMBLY is not set
# CONFIG_LWIP_IP_FORWARD is not set
# CONFIG_LWIP_STATS is not set
# CONFIG_LWIP_ETHARP_TRUST_IP_MAC is not set
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
# CONFIG_LWIP_DHCP_DOES_ARP_CHECK is not set
# CONFIG_LWIP_DHCP_DISABLE_CLIENT_ID is not set
CONFIG_LWIP_DHCP_DISABLE_VENDOR_CLASS_ID=y
# CONFIG_LWIP_DHCP_RESTORE_LAST_IP is not set
CONFIG_LWIP_DHCP_OPTIONS_LEN=68
# DHCP server
# CONFIG_LWIP_DHCPS is not set
# end of DHCP server
# CONFIG_LWIP_AUTOIP is not set
CONFIG_LWIP_IPV6=y
# CONFIG_LWIP_IPV6_AUTOCONFIG is not set
CONFIG_LWIP_IPV6_NUM_ADDRESSES=3
# CONFIG_LWIP_IPV6_FORWARD is not set
# CONFIG_LWIP_NETIF_STATUS_CALLBACK is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_LWIP_TCP_HIGH_SPEED_RETRANSMISSION=y
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=12
CONFIG_LWIP_TCP_MSS=1440
CONFIG_LWIP_TCP_TMR_INTERVAL=250
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
# CONFIG_LWIP_TCP_SACK_OUT is not set
# CONFIG_LWIP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
# CONFIG_LWIP_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_LWIP_TCP_OVERSIZE_DISABLE is not set
CONFIG_LWIP_TCP_RTO_TIME=1500
# end of TCP
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
# end of UDP
# Checksums
# CONFIG_LWIP_CHECKSUM_CHECK_IP is not set
# CONFIG_LWIP_CHECKSUM_CHECK_UDP is not set
CONFIG_LWIP_CHECKSUM_CHECK_ICMP=y
# end of Checksums
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=3072
CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_LWIP_PPP_SUPPORT is not set
CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE=3
CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS=5
# CONFIG_LWIP_SLIP_SUPPORT is not set
# ICMP
CONFIG_LWIP_ICMP=y
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
# end of ICMP
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# end of LWIP RAW API
# SNTP
CONFIG_LWIP_SNTP_MAX_SERVERS=1
# CONFIG_LWIP_DHCP_GET_NTP_SRV is not set
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
# end of SNTP
CONFIG_LWIP_ESP_LWIP_ASSERT=y
# Hooks
# CONFIG_LWIP_HOOK_TCP_ISN_NONE is not set
CONFIG_LWIP_HOOK_TCP_ISN_DEFAULT=y
# CONFIG_LWIP_HOOK_TCP_ISN_CUSTOM is not set
CONFIG_LWIP_HOOK_IP6_ROUTE_NONE=y
# CONFIG_LWIP_HOOK_IP6_ROUTE_DEFAULT is not set
# CONFIG_LWIP_HOOK_IP6_ROUTE_CUSTOM is not set
CONFIG_LWIP_HOOK_ND6_GET_GW_NONE=y
# CONFIG_LWIP_HOOK_ND6_GET_GW_DEFAULT is not set
# CONFIG_LWIP_HOOK_ND6_GET_GW_CUSTOM is not set
CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_NONE=y
# CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_DEFAULT is not set
# CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_CUSTOM is not set
# end of Hooks
# CONFIG_LWIP_DEBUG is not set
# end of LWIP
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DYNAMIC_BUFFER is not set
# CONFIG_MBEDTLS_DEBUG is not set
# Certificate Bundle
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE=y
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL=y
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_CMN is not set
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_NONE is not set
# CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE is not set
# end of Certificate Bundle
# CONFIG_MBEDTLS_ECP_RESTARTABLE is not set
# CONFIG_MBEDTLS_CMAC_C is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_ROM_MD5=y
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_SIGN is not set
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_VERIFY is not set
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
CONFIG_MBEDTLS_SHA512_C=y
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
# end of TLS Key Exchange Methods
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
# CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_GMTSSL1_1 is not set
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y
CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
CONFIG_MBEDTLS_RC4_DISABLED=y
# CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set
# CONFIG_MBEDTLS_RC4_ENABLED is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_NIST_KW_C is not set
# end of Symmetric Ciphers
# CONFIG_MBEDTLS_RIPEMD160_C is not set
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# end of Certificates
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
# CONFIG_MBEDTLS_ECJPAKE_C is not set
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_HKDF_C is not set
# CONFIG_MBEDTLS_THREADING_C is not set
# CONFIG_MBEDTLS_LARGE_KEY_SOFTWARE_MPI is not set
# CONFIG_MBEDTLS_SECURITY_RISKS is not set
# end of mbedTLS
# mDNS
CONFIG_MDNS_MAX_SERVICES=10
CONFIG_MDNS_TASK_PRIORITY=1
CONFIG_MDNS_TASK_STACK_SIZE=4096
# CONFIG_MDNS_TASK_AFFINITY_NO_AFFINITY is not set
CONFIG_MDNS_TASK_AFFINITY_CPU0=y
# CONFIG_MDNS_TASK_AFFINITY_CPU1 is not set
CONFIG_MDNS_TASK_AFFINITY=0x0
CONFIG_MDNS_SERVICE_ADD_TIMEOUT_MS=2000
# CONFIG_MDNS_STRICT_MODE is not set
CONFIG_MDNS_TIMER_PERIOD_MS=100
# CONFIG_MDNS_NETWORKING_SOCKET is not set
CONFIG_MDNS_MULTIPLE_INSTANCE=y
# end of mDNS
# ESP-MQTT Configurations
CONFIG_MQTT_PROTOCOL_311=y
CONFIG_MQTT_TRANSPORT_SSL=y
# CONFIG_MQTT_MSG_ID_INCREMENTAL is not set
CONFIG_MQTT_SKIP_PUBLISH_IF_DISCONNECTED=y
# CONFIG_MQTT_REPORT_DELETED_MESSAGES is not set
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
# end of ESP-MQTT Configurations
# Newlib
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
# end of Newlib
# NVS
# end of NVS
# OpenSSL
# CONFIG_OPENSSL_DEBUG is not set
CONFIG_OPENSSL_ERROR_STACK=y
# CONFIG_OPENSSL_ASSERT_DO_NOTHING is not set
CONFIG_OPENSSL_ASSERT_EXIT=y
# end of OpenSSL
# SPI Flash driver
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS=y
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_FAILS is not set
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_ALLOWED is not set
# CONFIG_SPI_FLASH_USE_LEGACY_IMPL is not set
# CONFIG_SPI_FLASH_SHARE_SPI1_BUS is not set
# CONFIG_SPI_FLASH_BYPASS_BLOCK_ERASE is not set
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
CONFIG_SPI_FLASH_WRITE_CHUNK_SIZE=8192
# CONFIG_SPI_FLASH_SIZE_OVERRIDE is not set
# CONFIG_SPI_FLASH_CHECK_ERASE_TIMEOUT_DISABLED is not set
# CONFIG_SPI_FLASH_OVERRIDE_CHIP_DRIVER_LIST is not set
# Auto-detect flash chips
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_MXIC_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_WINBOND_CHIP=y
# end of Auto-detect flash chips
CONFIG_SPI_FLASH_ENABLE_ENCRYPTED_READ_WRITE=y
# end of SPI Flash driver
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=5
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
# end of SPIFFS Cache Configuration
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
# CONFIG_SPIFFS_FOLLOW_SYMLINKS is not set
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
# end of Debug Configuration
# end of SPIFFS Configuration
# TCP Transport
# Websocket
# CONFIG_WS_TRANSPORT is not set
# end of Websocket
# end of TCP Transport
# Unity unit testing library
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_64BIT is not set
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
# CONFIG_UNITY_ENABLE_BACKTRACE_ON_FAIL is not set
# end of Unity unit testing library
# Virtual file system
CONFIG_VFS_SUPPORT_IO=y
CONFIG_VFS_SUPPORT_DIR=y
CONFIG_VFS_SUPPORT_SELECT=y
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
# Host File System I/O (Semihosting)
CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS=1
CONFIG_VFS_SEMIHOSTFS_HOST_PATH_MAX_LEN=128
# end of Host File System I/O (Semihosting)
# end of Virtual file system
# Wear Levelling
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
# end of Wear Levelling
# Wi-Fi Provisioning Manager
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=8
CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=5
# CONFIG_WIFI_PROV_BLE_BONDING is not set
# end of Wi-Fi Provisioning Manager
# Supplicant
CONFIG_WPA_MBEDTLS_CRYPTO=y
# CONFIG_WPA_WAPI_PSK is not set
# CONFIG_WPA_SUITE_B_192 is not set
# CONFIG_WPA_DEBUG_PRINT is not set
# CONFIG_WPA_TESTING_OPTIONS is not set
# CONFIG_WPA_WPS_STRICT is not set
# CONFIG_WPA_11KV_SUPPORT is not set
# end of Supplicant
# end of Component config
# Compatibility options
# CONFIG_LEGACY_INCLUDE_COMMON_HEADERS is not set
# end of Compatibility options
# Deprecated options for backward compatibility
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_LOG_BOOTLOADER_LEVEL_NONE=y
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_WARN is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_INFO is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=0
# CONFIG_APP_ROLLBACK_ENABLE is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
# CONFIG_FLASHMODE_QIO is not set
# CONFIG_FLASHMODE_QOUT is not set
CONFIG_FLASHMODE_DIO=y
# CONFIG_FLASHMODE_DOUT is not set
# CONFIG_MONITOR_BAUD_9600B is not set
# CONFIG_MONITOR_BAUD_57600B is not set
# CONFIG_MONITOR_BAUD_115200B is not set
# CONFIG_MONITOR_BAUD_230400B is not set
# CONFIG_MONITOR_BAUD_921600B is not set
# CONFIG_MONITOR_BAUD_2MB is not set
# CONFIG_MONITOR_BAUD_OTHER is not set
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
# CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG is not set
CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE=y
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
CONFIG_OPTIMIZATION_ASSERTION_LEVEL=2
CONFIG_CXX_EXCEPTIONS=y
CONFIG_CXX_EXCEPTIONS_EMG_POOL_SIZE=0
CONFIG_STACK_CHECK_NONE=y
# CONFIG_STACK_CHECK_NORM is not set
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
# CONFIG_WARN_WRITE_STRINGS is not set
# CONFIG_DISABLE_GCC8_WARNINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY=y
# CONFIG_BTDM_CONTROLLER_MODE_BR_EDR_ONLY is not set
# CONFIG_BTDM_CONTROLLER_MODE_BTDM is not set
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN=3
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=3
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
# CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4 is not set
CONFIG_BTDM_CONTROLLER_MODEM_SLEEP=y
CONFIG_BLE_SCAN_DUPLICATE=y
CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y
# CONFIG_SCAN_DUPLICATE_BY_ADV_DATA is not set
# CONFIG_SCAN_DUPLICATE_BY_ADV_DATA_AND_DEVICE_ADDR is not set
CONFIG_SCAN_DUPLICATE_TYPE=0
CONFIG_DUPLICATE_SCAN_CACHE_SIZE=200
# CONFIG_BLE_MESH_SCAN_DUPLICATE_EN is not set
CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100
CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
CONFIG_BLUEDROID_ENABLED=y
# CONFIG_NIMBLE_ENABLED is not set
CONFIG_BTC_TASK_STACK_SIZE=3072
CONFIG_BLUEDROID_PINNED_TO_CORE_0=y
# CONFIG_BLUEDROID_PINNED_TO_CORE_1 is not set
CONFIG_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BTU_TASK_STACK_SIZE=4096
# CONFIG_BLUEDROID_MEM_DEBUG is not set
# CONFIG_CLASSIC_BT_ENABLED is not set
CONFIG_GATTS_ENABLE=y
# CONFIG_GATTS_SEND_SERVICE_CHANGE_MANUAL is not set
CONFIG_GATTS_SEND_SERVICE_CHANGE_AUTO=y
CONFIG_GATTS_SEND_SERVICE_CHANGE_MODE=0
# CONFIG_GATTC_ENABLE is not set
# CONFIG_BLE_SMP_ENABLE is not set
# CONFIG_BLE_HOST_QUEUE_CONGESTION_CHECK is not set
# CONFIG_BLE_ACTIVE_SCAN_REPORT_ADV_SCAN_RSP_INDIVIDUALLY is not set
CONFIG_BLE_ESTABLISH_LINK_CONNECTION_TIMEOUT=30
CONFIG_ADC2_DISABLE_DAC=y
# CONFIG_SPIRAM_SUPPORT is not set
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ULP_COPROC_ENABLED is not set
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256 is not set
# CONFIG_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
# CONFIG_TWO_UNIVERSAL_MAC_ADDRESS is not set
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_ESP_SYSTEM_PD_FLASH=y
# CONFIG_ESP32C3_LIGHTSLEEP_GPIO_RESET_WORKAROUND is not set
CONFIG_IPC_TASK_STACK_SIZE=1536
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
CONFIG_ESP32_REDUCE_PHY_TX_POWER=y
# CONFIG_ESP32S2_PANIC_PRINT_HALT is not set
CONFIG_ESP32S2_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32S2_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32S2_PANIC_GDBSTUB is not set
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_MAIN_TASK_STACK_SIZE=3584
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART=y
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=300
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
# CONFIG_TASK_WDT_PANIC is not set
CONFIG_TASK_WDT_TIMEOUT_S=5
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_SW_COEXIST_ENABLE=y
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_MB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_MB_MASTER_DELAY_MS_CONVERT=200
CONFIG_MB_QUEUE_LENGTH=20
CONFIG_MB_SERIAL_TASK_STACK_SIZE=4096
CONFIG_MB_SERIAL_BUF_SIZE=256
CONFIG_MB_SERIAL_TASK_PRIO=10
CONFIG_MB_CONTROLLER_SLAVE_ID_SUPPORT=y
CONFIG_MB_CONTROLLER_SLAVE_ID=0x00112233
CONFIG_MB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_MB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_MB_CONTROLLER_STACK_SIZE=4096
CONFIG_MB_EVENT_QUEUE_TIMEOUT=20
# CONFIG_MB_TIMER_PORT_ENABLED is not set
CONFIG_MB_TIMER_GROUP=0
CONFIG_MB_TIMER_INDEX=0
# CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK is not set
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
# CONFIG_L2_TO_L3_COPY is not set
# CONFIG_USE_ONLY_LWIP_SELECT is not set
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=12
CONFIG_TCP_MSS=1440
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
# CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_PPP_SUPPORT is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_ESP32_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0 is not set
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1 is not set
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED is not set
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
CONFIG_SEMIHOSTFS_HOST_PATH_MAX_LEN=128
# End of deprecated options
[/Codebox]
Environment : Windows
IDF version : v4.4 release
IDE : Visual Studios
Board : ESP-Wroom-32E
Language : C/C++
mbratch
Re: ESP32 not getting ip from router
Postby mbratch » Fri May 13, 2022 11:41 am
You haven't said or shown exactly what the error is. It would be helpful to check the error codes in your wifi event handler when it fails to connect or to obtain a wifi address. Or to indicate if the wifi event handler never received a particular event.
shaqlain garana
Postby shaqlain garana » Fri May 13, 2022 12:42 pm
I am not getting error instead i am getting this logs each time its not getting IP address
I (60787) wifi: new :<2,1>, old:<2,0>, ap:<255,255>, sta:<2,1>, prof:1
I (60787) wifi:state: init -> auth (b0)
I (61787) wifi:state: auth -> init (200) <--- Specially this line
I (61787) wifi: new :<2,0>, old:<2,1>, ap:<255,255>, sta:<2,1>, prof:1
Please guide me hoe can i debug it in details if possible
YJM
Postby YJM » Mon May 16, 2022 6:23 am
It is more like wifi issue. ESP32 connect to router failed and so that no IP got.
Users browsing this forum: Amazon [Bot], Bing [Bot], PetalBot, Semrush [Bot] and 1 guest
