I am trying to upload a ".wav" (circa 32kB) file from the flash memory of ESP32 to Google Drive. Is there a way to do that and would you be able to suggest a way to approach this? I am currently trying to use a code that does the same thing, but with ESP-cam images, and the encoding is very confusing.
Thank you for any help!
Source: [Upload an image directly from ESP32-CAM to Google Driv][1]
[1]: https://github.com/gsampallo/esp32cam-g ... gdrive.ino
ESP32 .WAV file upload to Google Drive
rpiloverbd
Re: ESP32 .WAV file upload to Google Drive
Hi, have you got any clue from here?
https://how2electronics.com/how-to-send ... gle-drive/
robertobistel
Hi! I'm working on a similar system. The example I've seen is the ESP32 CAM.
Did you make any progress using audio files?
Users browsing this forum: Baidu [Spider], Google [Bot], PetalBot, Qwantbot, YisouSpider and 1 guest
