Turn off Log messages at runtime.
Kazuya91
Postby Kazuya91 » Wed Aug 23, 2017 11:40 am
i am new to this Forum and the ESP32 itself. I started programming with the ESP32 and I have a little problem.
When i run my code using "make monitor" to see whats going on, there are too many output/log messages from the ESP with the Tags like "boot", "heap_init", "esp_image" etc. which I dont need right now.
I would like to temporarily turn them off. I read the logging library here http://esp-idf.readthedocs.io/en/latest ... hlight=log
but to be honest I didnt understand.
Can someone help me? Would really appreciate that.
Re: Turn off Log messages at runtime.
Postby Sprite » Thu Aug 24, 2017 3:15 am
What exactly do you fail to understand? In general, you can turn off these messages either by raising the priority where stuff gets logged in 'make menuconfig', or runtime using a esp_log_level_set call.
Kazuya91
Postby Kazuya91 » Thu Aug 24, 2017 12:28 pm
in my Code i have the line
esp_log_level_set("*", ESP_LOG_NONE);
So in theory, all Outputs from every component should be turned off. But still there are output messages...
igrr
Postby igrr » Thu Aug 24, 2017 12:51 pm
Could the remaining messages be from the bootloader?
Bootloader log level can be set in menuconfig, in the bootloader settings menu
http://esp-idf.readthedocs.io/en/latest ... ader-level
Users browsing this forum: Bing [Bot], Semrush [Bot] and 3 guests
