ESP32-pico-d4 reboot loop
jblazeg
Postby jblazeg » Wed May 25, 2022 8:00 am
I try to run a simple example of code on a ESP32 but i runs into a bootloop:
st:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:12812
load:0xffffffff,len:-1
ets Jun  8 2016 00:22:57
I use arduino 1.8.3
Simple program:
  Serial.begin(115200);while(!Serial)
  pinMode(22,OUTPUT);
  Serial.print("done");
  Serial.print(".");
  delay(250);
Seems like the device cannot read the address and length of IRAM:
Segment 1: len 0x0044c load 0x3fff0030 file_offs 0x00000018 [BYTE_ACCESSIBLE,DRAM,DIRAM_DRAM]
Segment 2: len 0x03014 load 0x40078000 file_offs 0x0000046c [CACHE_APP]
Segment 3: len 0x00c04 load 0x40080400 file_offs 0x00003488 [IRAM]
GPIO6, 7, 8, 11, 16, 17 are unused as well as MTDO and MTDI
Any help would be highly appreciated.
Cheers
JB
Re: ESP32-pico-d4 reboot loop
Postby Sprite » Thu May 26, 2022 3:10 am
while(!Serial)
That doesn't sound right... aside from its use not immediately being obvious, it also takes the pinMode line into the while loop as there's no semicolon at the end.
jblazeg
Postby jblazeg » Mon May 30, 2022 5:36 am
Yeah tah was too obvious, sorry!
I changed the program code:
Serial.begin(115200);while(!Serial){}
pinMode(22,OUTPUT);
Serial.print(".");
delay(250);
Now I get:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
rst:0x10 (RTCWDT_RTC_RESET),boot:0x7 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
and it's stuck
Postby Sprite » Mon May 30, 2022 7:09 am
Does it still do that when you remove the pinMode line? Also, what hardware are you using; do you have a schematic or picture?
