Questions about wifi tx power
axellin
Postby axellin » Mon Jun 06, 2022 12:56 pm
Some questions about wifi tx powr:
1.
In the datasheet [1], table 18 only mentions TX powr for 11n and 11b mode.
What is the TX power (Min/Typ/Max) for 11g mode?
[1] https://espressif.com/sites/default/fil ... eet_en.pdf
2.
The sdkconfig has below default setting:
CONFIG_ESP_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP_PHY_MAX_TX_POWER=20
So the 20 dBm is greater than the Max value for 802.11n (Max 14 says by dathasheet) ?
(I'm confused because the esp_wifi_get_max_tx_power() shows the power is grater than Max value mentioned in datasheet.)
3.
I suppose by setting the country code, the device will automatically set proper Max tx power.
But in my test, changing country code seems does not change max tx power.
esp_wifi_get_max_tx_power() always return 78, i.e. 19.5 dBM.
Is this correct behavior?
Thanks.
tyethgundry
Re: Questions about wifi tx power
Postby tyethgundry » Thu Oct 24, 2024 7:14 am
Bumping this in case anyone has answers
Bryght-Richard
Postby Bryght-Richard » Fri Feb 07, 2025 8:20 pm
I would assume it's the same as the corresponding 11n mode(same modulator, same coding rate).
