Bluetooth classic only - no BLE
phi20402
Postby phi20402 » Wed Jun 08, 2022 7:21 am
I would like to use the Bluetooth classic only, so that BLE is deactivated and does not consume any current.
However when I select "BR/EDR only" in the menuconfig, my Android phone does not see the ESP32.
It only works when I am selecting "Bluetooth Dual Mode".
I am using a Firebeetle ESP32 dev board together PlatformIO VS-code extension and the Arduino + ESPIDF Framework.
Do you have any hint why it does not work with BT classic only?
Best Regards
Philipp
Here the BT-related SDK-Config lines:
CONFIG_BT_ENABLED=y
# CONFIG_BTDM_CTRL_MODE_BLE_ONLY is not set
CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY=y
# CONFIG_BTDM_CTRL_MODE_BTDM is not set
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN=2
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN=0
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_HCI=y
# CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_PCM is not set
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
# CONFIG_BTDM_CTRL_AUTO_LATENCY_EFF is not set
CONFIG_BTDM_CTRL_BLE_MAX_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN_EFF=2
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CTRL_PINNED_TO_CORE_0=y
# CONFIG_BTDM_CTRL_PINNED_TO_CORE_1 is not set
CONFIG_BTDM_CTRL_PINNED_TO_CORE=0
CONFIG_BTDM_CTRL_HCI_MODE_VHCI=y
# CONFIG_BTDM_CTRL_HCI_MODE_UART_H4 is not set
# CONFIG_BTDM_MODEM_SLEEP is not set
CONFIG_BTDM_BLE_SLEEP_CLOCK_ACCURACY_INDEX_EFF=1
CONFIG_BT_BLUEDROID_ENABLED=y
# CONFIG_BT_NIMBLE_ENABLED is not set
# CONFIG_BT_CONTROLLER_ONLY is not set
CONFIG_BT_BTC_TASK_STACK_SIZE=3072
CONFIG_BT_BLUEDROID_PINNED_TO_CORE_0=y
# CONFIG_BT_BLUEDROID_PINNED_TO_CORE_1 is not set
CONFIG_BT_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BT_BTU_TASK_STACK_SIZE=4096
# CONFIG_BT_BLUEDROID_MEM_DEBUG is not set
CONFIG_BT_CLASSIC_ENABLED=y
# CONFIG_BT_A2DP_ENABLE is not set
CONFIG_BT_SPP_ENABLED=y
# CONFIG_BT_HFP_ENABLE is not set
CONFIG_BT_SSP_ENABLED=y
# CONFIG_BT_BLE_ENABLED is not set
# CONFIG_BT_STACK_NO_LOG is not set
# CONFIG_BT_LOG_HCI_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_HCI_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_HCI_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_HCI_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_HCI_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_HCI_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_HCI_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_HCI_TRACE_LEVEL=2
# CONFIG_BT_LOG_BTM_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_BTM_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_BTM_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_BTM_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_BTM_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_BTM_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_BTM_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_BTM_TRACE_LEVEL=2
# CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_L2CAP_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_L2CAP_TRACE_LEVEL=2
# CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_RFCOMM_TRACE_LEVEL=2
# CONFIG_BT_LOG_SDP_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_SDP_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_SDP_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_SDP_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_SDP_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_SDP_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_SDP_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_SDP_TRACE_LEVEL=2
# CONFIG_BT_LOG_GAP_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_GAP_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_GAP_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_GAP_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_GAP_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_GAP_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_GAP_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_GAP_TRACE_LEVEL=2
# CONFIG_BT_LOG_BNEP_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_BNEP_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_BNEP_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_BNEP_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_BNEP_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_BNEP_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_BNEP_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_BNEP_TRACE_LEVEL=2
# CONFIG_BT_LOG_PAN_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_PAN_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_PAN_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_PAN_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_PAN_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_PAN_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_PAN_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_PAN_TRACE_LEVEL=2
# CONFIG_BT_LOG_A2D_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_A2D_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_A2D_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_A2D_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_A2D_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_A2D_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_A2D_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_A2D_TRACE_LEVEL=2
# CONFIG_BT_LOG_AVDT_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_AVDT_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_AVDT_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_AVDT_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_AVDT_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_AVDT_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_AVDT_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_AVDT_TRACE_LEVEL=2
# CONFIG_BT_LOG_AVCT_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_AVCT_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_AVCT_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_AVCT_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_AVCT_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_AVCT_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_AVCT_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_AVCT_TRACE_LEVEL=2
# CONFIG_BT_LOG_AVRC_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_AVRC_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_AVRC_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_AVRC_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_AVRC_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_AVRC_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_AVRC_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_AVRC_TRACE_LEVEL=2
# CONFIG_BT_LOG_MCA_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_MCA_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_MCA_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_MCA_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_MCA_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_MCA_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_MCA_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_MCA_TRACE_LEVEL=2
# CONFIG_BT_LOG_HID_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_HID_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_HID_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_HID_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_HID_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_HID_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_HID_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_HID_TRACE_LEVEL=2
# CONFIG_BT_LOG_APPL_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_APPL_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_APPL_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_APPL_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_APPL_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_APPL_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_APPL_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_APPL_TRACE_LEVEL=2
# CONFIG_BT_LOG_GATT_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_GATT_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_GATT_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_GATT_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_GATT_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_GATT_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_GATT_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_GATT_TRACE_LEVEL=2
# CONFIG_BT_LOG_SMP_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_SMP_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_SMP_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_SMP_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_SMP_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_SMP_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_SMP_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_SMP_TRACE_LEVEL=2
# CONFIG_BT_LOG_BTIF_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_BTIF_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_BTIF_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_BTIF_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_BTIF_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_BTIF_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_BTIF_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_BTIF_TRACE_LEVEL=2
# CONFIG_BT_LOG_BTC_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_BTC_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_BTC_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_BTC_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_BTC_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_BTC_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_BTC_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_BTC_TRACE_LEVEL=2
# CONFIG_BT_LOG_OSI_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_OSI_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_OSI_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_OSI_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_OSI_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_OSI_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_OSI_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_OSI_TRACE_LEVEL=2
# CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_NONE is not set
# CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_ERROR is not set
CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_WARNING=y
# CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_API is not set
# CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_EVENT is not set
# CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_DEBUG is not set
# CONFIG_BT_LOG_BLUFI_TRACE_LEVEL_VERBOSE is not set
CONFIG_BT_LOG_BLUFI_TRACE_LEVEL=2
CONFIG_BT_ACL_CONNECTIONS=4
# CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST is not set
# CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY is not set
# CONFIG_BT_BLE_HOST_QUEUE_CONG_CHECK is not set
CONFIG_BT_SMP_ENABLE=y
CONFIG_BT_BLE_ESTAB_LINK_CONN_TOUT=30
CONFIG_BT_RESERVE_DRAM=0xdb5c
# CONFIG_BLE_MESH is not set
Users browsing this forum: PerplexityBot and 4 guests
