Unknown CMake command "idf_build_get_property".
xXWesleyXx eckz
Postby xXWesleyXx eckz » Fri Jun 10, 2022 12:30 pm
hello,
i'd like to start off saying i'm an intern with no ESP programming experience so please forgive because I this question will probably not be asked correctly.
We have a bunch of code that has been in an ESP32 before but that has been done by an external company and they won't share a thing unless they get a lot of money.
So i've been trying to do this for the past 2 weeks but VSCode keeps nagging about a million different things.
The thing that bullies me currently is the following message:
Code: Untitled.txt Select all
CMake Error at C:/Users/Wesley/esp/esp-idf/components/freertos/CMakeLists.txt:7 (idf_build_get_property):
I've been googling and googling but I cannot find anything on how to get this command to work.
I could go and change all the CMakeLists but then it gets very frustrating again when I want to use a new/different version of esp-idf.
Also that's a lot of CMakeLists to change.
This is my root makelist:
cmake_minimum_required(VERSION 3.0)
#include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(main)
add_subdirectory($ENV{IDF_PATH}/components/freertos include EXCLUDE_FROM_ALL)
#include_directories(${PROJECT_SOURCE_DIR}/include)
#include_directories($ENV{IDF_PATH}/components/freertos)
#include_directories($ENV{IDF_PATH}/components/esp_common)
#include_directories($ENV{IDF_PATH}/components/xtensa)
#include_directories($ENV{IDF_PATH}/components/esp_rom)
#include_directories($ENV{IDF_PATH}/components/esp_timer)
add_executable(main ${CMAKE_CURRENT_SOURCE_DIR}/main.c)
And this is the file that causes trouble:
if(BOOTLOADER_BUILD)
# bootloader only needs FreeRTOS for config, not for anything else
idf_component_register()
return()
endif()
idf_build_get_property(target IDF_TARGET)
if(CONFIG_FREERTOS_SMP)
if(CONFIG_IDF_TARGET_ARCH_XTENSA)
set(srcs
"FreeRTOS-Kernel-SMP/portable/xtensa/port.c"
"FreeRTOS-Kernel-SMP/portable/xtensa/portasm.S"
"FreeRTOS-Kernel-SMP/portable/xtensa/xtensa_context.S"
"FreeRTOS-Kernel-SMP/portable/xtensa/xtensa_init.c"
"FreeRTOS-Kernel-SMP/portable/xtensa/xtensa_overlay_os_hook.c"
"FreeRTOS-Kernel-SMP/portable/xtensa/xtensa_vector_defaults.S"
"FreeRTOS-Kernel-SMP/portable/xtensa/xtensa_vectors.S")
set(include_dirs
"FreeRTOS-Kernel-SMP/include" # FreeRTOS headers via #include "freertos/xxx.h"
"esp_additions/include/freertos" # For config via #include "FreeRTOSConfig.h"
"FreeRTOS-Kernel-SMP/portable/xtensa/include" # Xtensa/Arch Config headers via #include "freertos/xxx.h"
"esp_additions/include" # For #include "freertos/task_snapshot.h" and #include "freertos/FreeRTOSConfig.h"
"FreeRTOS-Kernel-SMP/portable/xtensa/include/freertos") # Xtensa headers via #include "xxx.h"
set(private_include_dirs
"FreeRTOS-Kernel-SMP/portable/xtensa"
endif()
list(APPEND srcs
"FreeRTOS-Kernel-SMP/croutine.c"
"FreeRTOS-Kernel-SMP/event_groups.c"
"FreeRTOS-Kernel-SMP/list.c"
"FreeRTOS-Kernel-SMP/queue.c"
"FreeRTOS-Kernel-SMP/tasks.c"
"FreeRTOS-Kernel-SMP/timers.c"
"FreeRTOS-Kernel-SMP/stream_buffer.c"
"FreeRTOS-openocd.c"
list(APPEND private_include_dirs
"FreeRTOS-Kernel-SMP/include/freertos" # FreeRTOS headers via #include "xxx.h"
"esp_additions/private_include") # For include "freertos_tasks_c_additions.h"
if(CONFIG_ESP32_IRAM_AS_8BIT_ACCESSIBLE_MEMORY)
list(APPEND srcs "FreeRTOS-Kernel-SMP/portable/xtensa/xtensa_loadstore_handler.S")
endif()
else()
set(srcs
"FreeRTOS-Kernel/portable/xtensa/port.c"
"FreeRTOS-Kernel/portable/xtensa/portasm.S"
"FreeRTOS-Kernel/portable/xtensa/xtensa_context.S"
"FreeRTOS-Kernel/portable/xtensa/xtensa_init.c"
"FreeRTOS-Kernel/portable/xtensa/xtensa_overlay_os_hook.c"
"FreeRTOS-Kernel/portable/xtensa/xtensa_vector_defaults.S"
"FreeRTOS-Kernel/portable/xtensa/xtensa_vectors.S")
set(include_dirs
FreeRTOS-Kernel/include
esp_additions/include/freertos # For files with #include "FreeRTOSConfig.h"
FreeRTOS-Kernel/portable/xtensa/include # For arch-specific FreeRTOSConfig_arch.h in portable/<arch>/include
esp_additions/include) # For files with #include "freertos/FreeRTOSConfig.h"
FreeRTOS-Kernel/portable/xtensa/include/freertos
FreeRTOS-Kernel/portable/priv_include
elseif(CONFIG_IDF_TARGET_ARCH_RISCV)
set(srcs
"FreeRTOS-Kernel/portable/riscv/port.c"
"FreeRTOS-Kernel/portable/riscv/portasm.S")
set(include_dirs
FreeRTOS-Kernel/portable/riscv/include # For arch-specific FreeRTOSConfig_arch.h in portable/<arch>/include
FreeRTOS-Kernel/portable/riscv/include/freertos
endif()
list(APPEND srcs
"FreeRTOS-Kernel/portable/port_common.c"
"FreeRTOS-Kernel/portable/port_systick.c"
"FreeRTOS-Kernel/croutine.c"
"FreeRTOS-Kernel/event_groups.c"
"FreeRTOS-Kernel/list.c"
"FreeRTOS-Kernel/queue.c"
"FreeRTOS-Kernel/tasks.c"
"FreeRTOS-Kernel/timers.c"
"FreeRTOS-Kernel/stream_buffer.c"
"esp_additions/freertos_v8_compat.c")
"FreeRTOS-Kernel/include/freertos"
list(APPEND srcs "FreeRTOS-Kernel/portable/xtensa/xtensa_loadstore_handler.S")
endif()
endif()
idf_component_register(SRCS "${srcs}"
INCLUDE_DIRS ${include_dirs}
PRIV_INCLUDE_DIRS ${private_include_dirs}
LDFRAGMENTS linker.lf
PRIV_REQUIRES soc esp_pm)
idf_component_get_property(COMPONENT_DIR freertos COMPONENT_DIR)
idf_component_set_property(freertos ORIG_INCLUDE_PATH "${COMPONENT_DIR}/include/freertos/")
if(CONFIG_FREERTOS_DEBUG_OCDAWARE)
target_link_libraries(${COMPONENT_LIB} INTERFACE "-Wl,--undefined=uxTopUsedPriority") #will be removed
target_link_libraries(${COMPONENT_LIB} INTERFACE "-Wl,--undefined=FreeRTOS_openocd_params")
idf_build_set_property(COMPILE_OPTIONS "-DconfigENABLE_FREERTOS_DEBUG_OCDAWARE=1" APPEND)
endif()
set_source_files_properties(
tasks.c
event_groups.c
timers.c
queue.c
stream_buffer.c
PROPERTIES COMPILE_DEFINITIONS
_ESP_FREERTOS_INTERNAL
# The freertos component provides the `start_app` and `start_app_other_cores`
# if it is included in the build. It then calls `app_main`
# from the main task created, which must be provided by the user.
# Like for `start_app` and `start_app_other_cores`,
# we can't establish dependency on what we don't yet know, so we force the
# linker to not drop this symbol.
target_link_libraries(${COMPONENT_LIB} INTERFACE "-u app_main")
if(CONFIG_APPTRACE_SV_ENABLE)
# FreeRTOS headers have a dependency on app_trace when SystemView tracing is enabled
idf_component_optional_requires(PUBLIC app_trace)
elseif(CONFIG_APPTRACE_ENABLE)
# [refactor-todo]: port.c has a dependency on esp_apptrace_init, for running it on APP CPU.
# this should be resolved when link-time registration of startup functions is added.
idf_component_optional_requires(PRIVATE app_trace)
endif()
if(CONFIG_ESP_SYSTEM_GDBSTUB_RUNTIME)
# [refactor-todo]: port.c esp_startup_start_app_common() calls esp_gdbstub_init()
idf_component_optional_requires(PRIVATE esp_gdbstub)
endif()
if(CONFIG_FREERTOS_RUN_TIME_STATS_USING_ESP_TIMER)
# [refactor-todo]: esp_timer is required by FreeRTOS when we use esp_timer_get_time() to do profiling
# Introduce a port wrapper function to avoid including esp_timer.h into the public header
idf_component_optional_requires(PUBLIC esp_timer)
endif()
EVERY freaking tutorial on the internet isn't fixing this problem and it's making my blood boil.
How in the name of Freddie Mercury can I get this and similar idf_blah commands to work
Regards,
Wesley
PS if you need more info please ask and I will try to supply it.
Re: Unknown CMake command "idf_build_get_property".
Postby Sprite » Sat Jun 11, 2022 2:03 am
#include "bla" is C for 'include this'. #include "bla" in CMake is 'the following is a comment and should be disregarded: include "bla"'
xXWesleyXx eckz
Postby xXWesleyXx eckz » Mon Jun 13, 2022 7:47 am
I know what a comment is, that wasn't what I asked about, ignore the comments.
Postby Sprite » Mon Jun 13, 2022 8:34 am
So why did you comment out 'include($ENV{IDF_PATH}/tools/cmake/project.cmake)' then? You don't get the ESP-IDF build system if you do that, which makes any ESP-IDF specific call fail.
Users browsing this forum: ChatGPT-User, Google [Bot], PerplexityBot and 2 guests
