Use CMD like terminal inside Espressif_IDE IDE
marcusob
Postby marcusob » Sun Jun 12, 2022 10:47 pm
Hi
I would like to know how I can type and interact with the command like environment running Espressif_IDE in Windows 10 . I can build, watch serial etc, but cant seem to use the terminal.
I do this
1. Click on menu bar - Window -> Show View -> Terminal
2. Go down to the terminal windows and click on "Launch Terminal" icon
3. Select from Choose Terminal : ESP-IDF Terminal and Encoding : UTF-8, hit OK
4. The following prompt appears and some text
Microsoft Windows [Version 10.0.19044.1706]
(c) Microsoft Corporation. All rights reserved.
u:\Esp_idf_ide\frameworks\esp-idf-v4.4>
5. Now if I type anything it appears as normal, but when I hit return nothing happens
u:\Esp_idf_ide\frameworks\esp-idf-v4.4>dir
How can I use a command type terminal inside the IDE ?
Versions and Stuff
Version: 2.4.2
Build id: 20220308-1406
ESP-IDF : 4.4
