Is 'rollup' a part of the standard tools and build environment?
Melbourne
Postby Melbourne » Mon Jun 13, 2022 3:42 am
I'm trying to use expressif idf v4.1.2 to build a project I've inherited, like this:
docker run --rm -v f:\projects\myproject\firmware :/firmware -w /firmware -it espressif/idf:v4.1.2
That command finds the espressif idf container tagged v4.1.2 and creates an image linked to my firmware folder.
When I do
idf.py build
it gets only to line 5 of step 2, and fails on the command 'rollup':
[2/102] Generating rofs_data.c
FAILED: esp-idf/rest/rofs_data.c
cd /firmware/build/esp-idf/rest &&
cp /firmware/www/src/html/index.html /firmware/www/embedded/index.html &&
cp /firmware/www/src/html/my.mib /firmware/www/embedded/my.mib &&
cp /firmware/www/src/html/favicon32x32.png /firmware/www/embedded/favicon32x32.png &&
rollup /firmware/www/src/js/my.js --file /firmware/www/src/app.js --format iife &&
uglifyjs /firmware/www/src/app.js -c -m -o /firmware/www/embedded/app.js &&
/firmware/www/rofs/makerofs -d /firmware/www/embedded -o /firmware/components/rest/rofs_data.c
/bin/sh: 1: rollup: not found
cf rollup: https://rollupjs.org/guide/en/
I don't know where rollup and uglifyjs are supposed to come from. Is there a problem with my project, or is the problem with the v4.1.2 docker container?
Re: Is 'rollup' a part of the standard tools and build environment?
Postby Sprite » Mon Jun 13, 2022 8:32 am
Sounds like the project you have there has some custom magic in its makefiles in order to invoke those tools. From what I'm aware, they're not standard for ESP-IDF.
Users browsing this forum: No registered users and 9 guests
