serial bluetooth and ESP NOW
zachtos
Postby zachtos » Thu Jun 16, 2022 12:02 am
I am not able to get ESP NOW to function properly while using the built in serial bluetooth library.
    char *pin = "123";//"R069D"; //<- standard pin would be provided by default
    SerialBT.begin("abc");//, false);
    SerialBT.setPin(pin);
    esp_err_t err;
    WiFi.mode(WIFI_STA);
err = esp_now_init();
    if (err != ESP_OK)
      Serial.println("Problem during ESP-NOW init");
      ESP.restart();
      return;
    else
      espNowStarted = true;
      Serial.println("ESP-NOW init OK");
    Serial.print("[OLD] ESP32 Board MAC Address:  ");
    Serial.println(WiFi.macAddress());
    esp_now_register_recv_cb(OnDataRecv);
    esp_now_register_send_cb(OnDataSent);
  // register peer
    esp_now_peer_info_t peerInfo;
    peerInfo.channel = 0;
    peerInfo.encrypt = false;
    // register first peer
      memcpy(peerInfo.peer_addr, peerAdmin, 6);
    if (esp_now_add_peer(&peerInfo) != ESP_OK){
      Serial.println("Failed to add peer");
      ESP.restart();
      return;
    memcpy(peerInfo.peer_addr, espAll, 6); //can also broadcast with zero (0) which does each individual
    if (esp_now_add_peer(&peerInfo) != ESP_OK){ //delivery success always with 0xFF broadcast, so no ack in that mode
      ESP.restart();
      return;
I can send but not receive, I'm trying broadcast address and it does not work. If I switch back to BLE mode, everything is fine. What am I missing about the basic compatibilities of ESP NOW with serialBluetooth?
rpiloverbd
Re: serial bluetooth and ESP NOW
Postby rpiloverbd » Fri Jun 17, 2022 11:11 am
Have you checked the baud rates of sender and receiver devices?
Users browsing this forum: ChatGPT-User, PetalBot, Semrush [Bot] and 17 guests
