OpenOCD debug issue
alexey_powers
OpenOCD debug issue
Postby alexey_powers » Mon Jun 27, 2022 1:45 pm
Hello!
Trying to debug ESP32 simple blink app, no luck so far. Console output:
Open On-Chip Debugger  v0.11.0-esp32-20211220 (2021-12-20-15:43)
Licensed under GNU GPL v2
For bug reports, read
DEPRECATED! use 'adapter driver' not 'interface'
DEPRECATED! use 'adapter speed' not 'adapter_khz'
adapter speed: 200 kHz
Warn : Interface already configured, ignoring
Warn : Transport "jtag" was already selected
Started by GNU MCU Eclipse
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Warn : target esp32.cpu1 examination failed
Info : esp32.cpu0: Target halted, PC=0x40008544, debug_reason=00000000
Info : starting gdb server for esp32.cpu0 on 3333
Info : esp32.cpu0: Target halted, PC=0x40092AEE, debug_reason=00000001
Info : Set GDB target to 'esp32.cpu0'
Error: Failed to get flash maps (4294967295)!
Warn : Failed to get flash mappings (-4)!
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 16384 KB
Info : Using flash bank 'esp32.cpu0.flash' size 16384 KB
Info : Using flash bank 'esp32.cpu0.irom' size 0 KB
Info : Using flash bank 'esp32.cpu0.drom' size 0 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Warn : Prefer GDB command "target extended-remote 3333" instead of "target remote 3333"
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
invalid command name "arm"
Warn : address 0x3f400020 not writable
Warn : address 0x3f400120 not writable
Info : dropped 'gdb' connection
shutdown command invoked
and finaly:
Error in final launch sequence
Failed to execute MI command:
load C:\\ESP-IDF\\frameworks\\esp-idf-v4.4\\workspace\\blink\\build\\blink.elf
Error message from debugger back end:
Load failed
Load failed
Load failed
zfields
Re: OpenOCD debug issue
Postby zfields » Mon Jun 27, 2022 9:25 pm
I'm at tip of `master` and I'm having this _EXACT_ same issue.
Debugging has always worked for me.
I tried rolling back to `4.4.1` and `4.3.3` but no luck. I've been pulling my hair out all weekend.
Here is my exact log:
~/esp-idf$ openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f target/esp32.cfg -c "program_esp ../Development/Arduino/EpiCAT/build/EpiCAT.ino.bin 0x10000 verify reset exit"
Open On-Chip Debugger v0.11.0-esp32-20220411 (2022-04-11-08:47)
adapter speed: 20000 kHz
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : esp32.cpu0: Target halted, PC=0x4000F979, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x400076DD, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x4009260E, debug_reason=00000001
Error: Failed to get flash maps (4294967290)!
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Info : PROF: Data transferred in 935.502 ms @ 324.959 KB/s
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
alexey_powers
Postby alexey_powers » Tue Jun 28, 2022 8:01 am
So partly issue resolution can be found in https://github.com/espressif/openocd-esp32/issues/223
openocd-esp32-win32-0.11.0-esp32-20211220-1339-g187c87957 version
But there is another problem now: After application uploading debug output looks like this:
alexey_powers
Postby alexey_powers » Tue Jun 28, 2022 8:32 am
and finally I choose the correct configuration - ESP-IDF GDB OpenOCD Debugging, with default settings - all worked out well.
Users browsing this forum: Bytespider, PetalBot, Semrush [Bot] and 1 guest
