Stuck with Hello_World example
usinjin
Postby usinjin » Wed Aug 30, 2017 6:25 am
I'm fairly new to esp-idf. I believe I have my board set up correctly (ESP-WROOM-32), as I have successfully flashed several different programs to it. However, I cannot get idf-monitor to work for me. For simplicity's sake, I'm trying to get the Hello_World program to print to the monitor as shown in the tutorial. Everything seems to go fine, as I get this output after making it:
esptool.py v2.1
Flashing binaries to serial port COM4 (app at offset 0x10000)...
esptool.py v2.1
Connecting....
Chip is ESP32D0WDQ6 (revision 0)
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Compressed 20608 bytes to 11504...
Wrote 20608 bytes (11504 compressed) at 0x00001000 in 1.0 seconds (effective 162.7 kbit/s)...
Hash of data verified.
Compressed 119712 bytes to 57091...
Wrote 119712 bytes (57091 compressed) at 0x00010000 in 5.0 seconds (effective 190.7 kbit/s)...
Compressed 3072 bytes to 82...
Wrote 3072 bytes (82 compressed) at 0x00008000 in 0.0 seconds (effective 1571.7 kbit/s)...
Leaving...
Hard resetting...
Then I do
make monitor
and get:
MONITOR
--- idf_monitor on COM4 115200 ---
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
But that's it. No part of the Hello_World program prints to the screen. What am I doing wrong?
Re: Stuck with Hello_World example
Postby Sprite » Wed Aug 30, 2017 8:16 am
The output you get indicates GPIO0 is stuck low, meaning the ESP32 will always go into download mode. Can you see if that's the case on your hardware?
Mozmallow
Postby Mozmallow » Thu Oct 03, 2019 1:23 pm
Hey did you solve this issue? I am also getting a similar message and my GPIO0 is not grounded.
What else can be wrong?
Users browsing this forum: Bytespider, DuckDuckGo [Bot], meta-externalagent, PerplexityBot and 2 guests
