CPU halting when working with timeval, gettimeofday()
youmebangbang
Postby youmebangbang » Thu Aug 31, 2017 2:43 am
Hi, I am trying to run a simple timer program to print to COM ever so many milliseconds. Code compiles just fine but when i run i get a CPU halted error , " Guru Meditation Error of type LoadProhibited occurred on core 1. Exception was unhandled." I know it has to be a simple problem (im learning).
#include <sys/time.h>
timeval *past_time;
timeval *current_time;
 gettimeofday(past_time, NULL);
  gettimeofday(current_time, NULL);
  if((current_time->tv_usec - past_time->tv_usec) > 2000)
    Serial.println(analogRead(32));
Re: CPU halting when working with timeval, gettimeofday()
Postby Sprite » Thu Aug 31, 2017 2:47 am
It's a C thing. You have declared current_time and past_time as pointers (presumably to a location that will contain the time). You do not initialize them, so they point at... nothing. Then you ask the gettimeofday function to put the current time at whereever the pointer is pointing at... which is essentially nowhere. The gettimeofday function call tries to do that, the CPU detects it's trying to do something that does not make sense (Write bytes to nowhere? Huh?) and panics.
I can tell you how to resolve this, but it may be more useful if you read up on pointers and see if you can fix this yourself with the above information.
youmebangbang
Postby youmebangbang » Thu Aug 31, 2017 2:00 pm
Great, thank you!
Users browsing this forum: Barkrowler, Qwantbot and 3 guests
