ESP-MDF + WebSocket
Ceranthor
ESP-MDF + WebSocket
Postby Ceranthor » Tue Jul 12, 2022 9:56 am
Hi i want to use ESP-MDF mesh and web socket to exchange data between computer and nodes.
I implement websocket as in an example in ESP-IDF and I cannot connect. I have connected WIFI and set everything as on the example just pasted it into mesh example.
my error:
E (615505) esp-tls: couldn't get hostname for :ws-postman.eu-gb.mybluemix.net: getaddrinfo() returns 202, addrinfo=0x0
E (615506) TRANSPORT_BASE: Failed to open a new connection: 32769
E (615513) TRANSPORT_WS: Error connecting to host ws-postman.eu-gb.mybluemix.net:80
E (615521) WEBSOCKET_CLIENT: Error transport connect
I (615527) WEBSOCKET_CLIENT: Reconnect after 10000 ms
I (615532) get_started: WEBSOCKET_EVENT_DISCONNECTED
I checked this hostname on example and it is working good - ws://ws-postman.eu-gb.mybluemix.net/ws/echo
What am I doing wrong?
#include "mdf_common.h"
#include "mwifi.h"
#include "esp_websocket_client.h"
#include "esp_log.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "esp_transport.h"
// #define MEMORY_DEBUG
#define NO_DATA_TIMEOUT_SEC 5
static const char *TAG = "get_started";
static void root_task(void *arg)
    mdf_err_t ret                    = MDF_OK;
    char *data                       = MDF_MALLOC(MWIFI_PAYLOAD_LEN);
    size_t size                      = MWIFI_PAYLOAD_LEN;
    uint8_t src_addr[MWIFI_ADDR_LEN] = {0x0};
    mwifi_data_type_t data_type      = {0};
    MDF_LOGI("Root is running");
    for (int i = 0;; ++i) {
        if (!mwifi_is_started()) {
            vTaskDelay(500 / portTICK_RATE_MS);
            continue;
        memset(data, 0, MWIFI_PAYLOAD_LEN);
        ret = mwifi_root_read(src_addr, &data_type, data, &size, portMAX_DELAY);
        MDF_ERROR_CONTINUE(ret != MDF_OK, "<%s> mwifi_root_read", mdf_err_to_name(ret));
        MDF_LOGI("Root receive, addr: " MACSTR ", size: %d, data: %s", MAC2STR(src_addr), size, data);
        size = sprintf(data, "(%d) Hello node!", i);
        ret = mwifi_root_write(src_addr, 1, &data_type, data, size, true);
        MDF_ERROR_CONTINUE(ret != MDF_OK, "mwifi_root_recv, ret: %x", ret);
        MDF_LOGI("Root send, addr: " MACSTR ", size: %d, data: %s", MAC2STR(src_addr), size, data);
    MDF_LOGW("Root is exit");
    MDF_FREE(data);
    vTaskDelete(NULL);
static void websocket_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
    esp_websocket_event_data_t *data = (esp_websocket_event_data_t *)event_data;
    switch (event_id) {
    case WEBSOCKET_EVENT_CONNECTED:
        ESP_LOGI(TAG, "WEBSOCKET_EVENT_CONNECTED");
    case WEBSOCKET_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "WEBSOCKET_EVENT_DISCONNECTED");
    case WEBSOCKET_EVENT_DATA:
        ESP_LOGI(TAG, "WEBSOCKET_EVENT_DATA");
        ESP_LOGI(TAG, "Received opcode=%d", data->op_code);
        if (data->op_code == 0x08 && data->data_len == 2) {
            ESP_LOGW(TAG, "Received closed message with code=%d", 256*data->data_ptr[0] + data->data_ptr[1]);
            ESP_LOGW(TAG, "Received=%.*s", data->data_len, (char *)data->data_ptr);
        ESP_LOGW(TAG, "Total payload length=%d, data_len=%d, current payload offset=%d\r\n", data->payload_len, data->data_len, data->payload_offset);
    case WEBSOCKET_EVENT_ERROR:
        ESP_LOGI(TAG, "WEBSOCKET_EVENT_ERROR");
static void websocket_app_start(void)
    esp_websocket_client_config_t websocket_cfg = {};
    websocket_cfg.uri = CONFIG_WEBSOCKET_URI;
    ESP_LOGI(TAG, "Connecting to %s...", websocket_cfg.uri);
    esp_websocket_client_handle_t client = esp_websocket_client_init(&websocket_cfg);
    esp_websocket_register_events(client, WEBSOCKET_EVENT_ANY, websocket_event_handler, (void *)client);
    esp_websocket_client_start(client);
    char data[32];
    int i = 0;
    while (true) {
        if (esp_websocket_client_is_connected(client)) {
            int len = sprintf(data, "hello %04d", i++);
            ESP_LOGI(TAG, "Sending %s", data);
            esp_websocket_client_send_text(client, data, len, portMAX_DELAY);
        vTaskDelay(2000 / portTICK_RATE_MS);
    esp_websocket_client_close(client, portMAX_DELAY);
    ESP_LOGI(TAG, "Websocket Stopped");
    esp_websocket_client_destroy(client);
static mdf_err_t wifi_init()
    mdf_err_t ret          = nvs_flash_init();
        MDF_ERROR_ASSERT(nvs_flash_erase());
    MDF_ERROR_ASSERT(ret);
    MDF_ERROR_ASSERT(esp_netif_init());
    MDF_ERROR_ASSERT(esp_event_loop_create_default());
    MDF_ERROR_ASSERT(esp_wifi_init(&cfg));
    MDF_ERROR_ASSERT(esp_wifi_set_storage(WIFI_STORAGE_FLASH));
    MDF_ERROR_ASSERT(esp_wifi_set_mode(WIFI_MODE_STA));
    MDF_ERROR_ASSERT(esp_wifi_set_ps(WIFI_PS_NONE));
    MDF_ERROR_ASSERT(esp_mesh_set_6m_rate(false));
    MDF_ERROR_ASSERT(esp_wifi_start());
    return MDF_OK;
 * @brief All module events will be sent to this task in esp-mdf
 * @Note:
 *     1. Do not block or lengthy operations in the callback function.
 *     2. Do not consume a lot of memory in the callback function.
 *        The task memory of the callback function is only 4KB.
static mdf_err_t event_loop_cb(mdf_event_loop_t event, void *ctx)
    MDF_LOGI("event_loop_cb, event: %d", event);
    switch (event) {
        case MDF_EVENT_MWIFI_STARTED:
            MDF_LOGI("MESH is started");
        case MDF_EVENT_MWIFI_PARENT_CONNECTED:
            MDF_LOGI("Parent is connected on station interface");
        case MDF_EVENT_MWIFI_PARENT_DISCONNECTED:
            MDF_LOGI("Parent is disconnected on station interface");
        default:
    return MDF_OK;
void app_main()
    mwifi_init_config_t cfg = MWIFI_INIT_CONFIG_DEFAULT();
    mwifi_config_t config   = {
        .router_ssid = "MAGLY",
        .router_password = "ilovemagly",
        .channel   = CONFIG_MESH_CHANNEL,
        .mesh_id   = CONFIG_MESH_ID,
        .mesh_type = MESH_ROOT,
     * @brief Set the log level for serial port printing.
    esp_log_level_set("*", ESP_LOG_INFO);
    esp_log_level_set(TAG, ESP_LOG_DEBUG);
     * @brief Initialize wifi mesh.
    MDF_ERROR_ASSERT(mdf_event_loop_init(event_loop_cb));
    MDF_ERROR_ASSERT(wifi_init());
    MDF_ERROR_ASSERT(mwifi_init(&cfg));
    MDF_ERROR_ASSERT(mwifi_set_config(&config));
    MDF_ERROR_ASSERT(mwifi_start());
     * @brief Data transfer between wifi mesh devices
        xTaskCreate(root_task, "root_task", 4 * 1024,
                    NULL, CONFIG_MDF_TASK_DEFAULT_PRIOTY, NULL);
    websocket_app_start();
Users browsing this forum: PetalBot, Qwantbot and 3 guests
