ESP32-WROOM-32U, No Serial Data Received
Junaid
Postby Junaid » Wed Jul 27, 2022 5:53 am
Hi, I'm currently working on my custom made PCB design circuit and the chip mount is ESP32-WROOM-32U. The problem is when i plugged in serial cable it detects serial com port correctly but soon when I try to flash code to esp32U chip it start connecting and then after few seconds it failed saying no serial data received . I have tried manual bootloader , tried to connect capacitor between EN and GND Pin, made GPIO active low when it start connecting but nothing works for me. My question is does the ESP32 fully new chip have write protection enable on it?? if so how can I remove it ?? I have used USB to serial chip CH430 . I have checked serial IC CH340 if it is working properly and send data from serial monitor and analyze on logic analyzer and obviously received correct byte of data I have sent from serial monitor. I'm stuck by this problem I'm not able to flash ESP32 chip even with a simple Blinky example. please if someone can help me in this regard. :cry: below here is schematic, error nature, and TX & RX pin response on logic analyzer during code upload.
2 (1).jpeg (82.74 KiB) Viewed 5860 times
LOGIC ANALYZER RESULT (RX and TX pin).JPG (255.88 KiB) Viewed 5860 times
ERROR - NO SERIAL DATA RECIEVED.jpeg (74.63 KiB) Viewed 5860 times
LJH
Re: ESP32-WROOM-32U, No Serial Data Received
Postby LJH » Wed Jul 27, 2022 9:56 am
1. Maybe you should show us more about your schematic related to ESP32 module, or please check if the power supply is enough, when you manually download, could you see "waiting for download" through UART0?
2. From the part you provide, I have to say it seems not correct for CH340G about VCC and V3. From datasheet, when V3 connects a decoupling cap, VCC should be around 5V ( usually connect to VUSB ); when you use 3.3 V VCC, you should connect V3 to VCC.
Junaid
Postby Junaid » Thu Jul 28, 2022 10:31 am
Hi ESP_LJH, hoping you will be well and good. well I see nothing when trying to enter download mode manually even I don't see my board response on serial monitor when I try to press EN button which shouldn't be the case. Here you can find the whole schematic I have excluded custom design connections. Please if you can review it and tell me the reason what's going wrong with it.
Postby Sprite » Fri Jul 29, 2022 2:24 am
With the board powered on and no button pressed, can you measure the voltage on the RSTB line?
Junaid
Postby Junaid » Fri Jul 29, 2022 4:58 am
hi , I have just confirmed voltage on RSTB line across resistor R8 and it was showing me 3.2xx with no button pressed, So after measuring it I then pressed RST Button to see its behavior and I just noticed voltage was same still same upon button press.
Junaid
Postby Junaid » Fri Jul 29, 2022 5:40 am
One more question to ask please if you can answer me ? does the ESP32 fully new SMDs comes with Write protection enable on it ?? if so how can I remove it ? May be I'm unable to flash my chip because of write protection enable on it . please need your comment on it.
Postby Sprite » Fri Jul 29, 2022 6:28 am
No, all ESP32 modules, chips and boards are programmable right off the factory.
Ondiii
Postby Ondiii » Wed May 10, 2023 6:16 pm
I am having the same issue.
Any update on this?
Users browsing this forum: PerplexityBot and 3 guests
