I plan to run an ESP32 with a 8 channel relay board and 5 DHT22.
The DHTs are connected via long cable (maybe 20m?). I run a similar setup with AM2301 and ESP8266.
Now I learned that the DHT22 is recommended to run at 5v, but the ESP32 GPIOs are not (officially?) 5V tolerant.
So my idea was to add two a level shifter to my setup. Is this the recommended way? Because I see a lot of post, where people just connect the 5V data pin to the GPIOs.
Br,
wolf70
ESP32 - DHT22 - Long Cable
Re: ESP32 - DHT22 - Long Cable
We suggest you to use level shifter, direct connection maybe work for a short-term test, but we could not guarantee long-term functionality.
