Hi, maybe this has been asked before but I can't find it (searching for non-trivial stuff is hard because the forum goes blank most of the time)
ESP-IDF has pthread support wrappers. Great! I have code that needs to be shared between Linux and ESP-IDF as much and as easily as possible, preferably using C++ std::thread and companions.
But is it possible to combine pthreads with some of FreeRTOS APIs such as MessageBuffers, EventGroups etc? That is: can I write to/read from a Stream/MessageBuffer, -Queue or use and EventGroup from a pthread ? I would think so since a pthread is in essence a FreeRTOS Task. Native FreeRTOS APIs are probably much more efficient than higher level constructs on top of the C++ thread API on top of the pthread support on top of FreeRTOS...
And secondly: is there a way to retrieve the Task handle for a pthread so that TaskNotifications can be used?
If so, I could write a few generic abstraction wrappers for synchronization objects and defer to the FreeRTOS ones when running on the ESP32.
Thanks in advance !
Bart
Mixing pthreads support and FreeRTOS APIs
- bartvanhofwegen
Users browsing this forum: Baidu [Spider], Semrush [Bot] and 7 guests
