Page 1 of 3
Need technical details on ESP32-MINI-1-N4
Posted: Sun Aug 28, 2022 1:15 pm
by Brijesh
Can i have reply for below queries for the ESP32-MINI-1-N4?
1) Can we connect external NOR flash on VSPICS0,VSPICLK,VSPID,VSPIQ of ESP32-MINI-1-N4?
2) Can we use GPIO0 as I2C_SDA and GPIO4 as I2C_SCL in ESP32-MINI-1-N4?
3) What max size of NOR flash can be connected with ESP32-MINI-1-N4?
4) Can we configure any GPIos as UART1 RTS & CTS of ESP32-MINI-1-N4?
Thanks,
Brijesh K
Re: Need technical details on ESP32-MINI-1-N4
Posted: Mon Aug 29, 2022 3:22 am
by LJH
I. Yes, you could use VSPI to connect a second flash, but just for storage, this flash could not share same function with the embedded one.
2. Yes, you could use them as I2C, but please add test point for IO0.
3. for storage, at least 16 MB, I have seen some cases, I will check it.
4. Yes, but please be noted those only for inputs can only be RX.
Posted: Mon Aug 29, 2022 3:35 am
by LJH
3. External storage flash could support up to 256 MB.
Posted: Wed Aug 31, 2022 3:11 am
by Brijesh
Than you so much for your valuable reply.
I will come if any new queries.
Brijesh K
Posted: Wed Aug 31, 2022 3:16 am
by Brijesh
sorry i missed one thing to ask,
Does ESP32-MINI-1-N4 module has in built RTC? Can we use it so that we can avoid external RTC usage?
Thanks,
Brijesh K
Posted: Wed Aug 31, 2022 11:44 am
by LJH
If you mean use a backup power for RTC supply to retain time, we could not support this function. We could enter into deep sleep for low power consumption while remaining RTC IO states.
Posted: Thu Sep 01, 2022 2:41 am
by Brijesh
"If you mean use a backup power for RTC supply to retain time, we could not support this function. We could enter into deep sleep for low power consumption while remaining RTC IO states"
->> Yes correct that I understood that it does not have back up supply for RTC.
But I was asking here for the Integrated RTC inside ESP32-MINI-1-N4. Does ESP32-MINI-1-N4 has integrated and can we use it?
Also can you please confirm that while ESP32-MINI-1-N4 is in deep sleep state will it retain real time?
Thanks,
Brijesh K
Posted: Thu Sep 01, 2022 3:07 am
by LJH
Yes, we have RTC function and could retain time while deep sleep.
Posted: Thu Sep 01, 2022 3:10 am
by Brijesh
OK thank you so much for quick reply and confirmation.
Regards,
Brijesh K
Posted: Sat Sep 10, 2022 3:46 am
by Brijesh
I need one help please.
In ESP32-MINI-1-N4 I see that there are additional 8 pins which are mentioned as GND but in schematic given in module datasheet they have connected pin55 only GND and not others so please suggest what to do of those all additional pins should connect all of them to GND OR connect only pin55 with GND and keep others NC.
Should I cover all of them into schematic symbol as well because in schematic i see only pin55 is covered?
Please see attached images for reference.
Thanks,
Brijesh K
