ESP32S3 Interfacing 8bit Display Using LVGL and ESP IDF
WardMas
Postby WardMas » Mon Aug 29, 2022 9:08 am
https://youtu.be/88MwR-4Dy0Q
In this tutorial I am sharing with you guys my experiment with ESP32S3 1.9 inch TFT T-Display development board from Lyligo, where I have managed to integrate LVGL display graphic library with ESP-IDF to build my own simple user interface and share my work on GitHub repository below.
I have also tested the board factory firmware to test the display capabilities.
The implemented code is explained in details. You can use lv_conf.h file as a reference for LVGL library configuration.
GitHub Repository:
https://github.com/UsefulElectronics/es ... splay_lvgl
You can always visit my YouTube channel for embedded systems related tutorials
https://youtube.com/user/wardzx1
