Jaguar: Dynamically install or update drivers on your ESP32
kasperl
Postby kasperl » Sat Sep 10, 2022 11:30 am
Hi all,
We've improved our open-source developer tooling ("Jaguar") for the ESP32 with support for dynamically installing or updating drivers and services without reflashing or rebooting your devices.
As an example, you can install an NTP-based time synchronization service on your device through:
$ jag container install ntp examples/ntp/ntp.toit
The service persists across reboots and it encapsulates the time synchronization code nicely in a memory-isolated container that doesn't interfere with your application code:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:320
load:0x40078000,len:13216
load:0x40080400,len:2964
entry 0x400805c8
[toit] INFO: starting <v2.0.0-alpha.22>
[jaguar] INFO: container 'ntp' started
[wifi] DEBUG: connecting
[wifi] DEBUG: connected
[wifi] INFO: network address dynamically assigned through dhcp {ip: 192.168.86.34}
[jaguar] INFO: running Jaguar device 'possible-teaching' on 'http://192.168.86.34:9000'
[ntp] INFO: synchronized {adjustment: 461886h45m59.639723406s, time: 2022-09-10T06:46:02}
You can also run complex drivers like the ones for cellular modems this way:
$ jag container install cellular-bg96 quectel-cellular/src/bg96.toit \
    -D cellular.uart.tx=17 \
    -D cellular.uart.rx=16 \
    -D cellular.apn=soracom.io
Once installed, using the cellular modem to provide a network is as easy as:
import cellular
import http
main:
  network := cellular.open
  client := http.Client network
  host := "www.google.com"
  response := client.get host "/"
  bytes := 0
  while data := response.body.read: bytes += data.size
  print "Read $bytes bytes from http://$host/ via cellular!"
Jaguar is based on the free and open-source Toit language implementation. You can download it from https://github.com/toitlang/jaguar and have it running on your device in less than 5 minutes. We'd love your feedback and can't wait to see what you build with this :)
Regards,
Kasper
kasperl
Re: Jaguar: Dynamically install or update drivers on your ESP32
Postby kasperl » Sun Sep 11, 2022 6:29 am
Oh, and if Discord is your kind of thing, you're very welcome to join the community discussions: https://chat.toit.io/.
Users browsing this forum: Amazon [Bot] and 2 guests
