父节点 一直报错: 非法子节点
(493102) mesh: 1316[recv]invalid child 68:b6:b3:3c:64:68
I (493102) mesh: 1316[recv]invalid child 68:b6:b3:3c:64:68
[0;32mI (493532) mesh_mqtt: MQTT_EVENT_PUBLISHED, msg_id=62348[0m
[0;32mI (493812) mesh_main: Tried to publish layer:1 IP:192.168.137.154[0m
[0;32mI (493812) mesh_mqtt: sent publish returned msg_id=1258[0m
[0;32mI (493812) mesh_main: Sending routing table to [0] f4:12:fa
[0;32mI (493812) mesh_main: Received Routing table [0] f4:12:fa
子节点 上电log如下:
I (7036) wifi:mode : sta (68:b6:b3:3c:64:68) + softAP (68:b6:b3:3c:64:69)
W (7056) wifi:<MESH AP>adjust channel:1, secondary channel offset:1(40U)
I (7066) wifi:Total power save buffer number: 16
[0;32mI (7066) mesh_main: <MESH_EVENT_FIND_NETWORK>new channel:6, router BSSID:00:00:00:00:00:00[0m
W (7096) wifi:<MESH AP>adjust channel:6, secondary channel offset:1(40U)
I (7096) wifi:Total power save buffer number: 16
[22:29:38.022]收←◆I (7406) mesh: [SCAN][ch:6]AP:6, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:0,i:0][0e:9a:3c:87:53:52]router found<>
I (7406) mesh: 7369[selection]try rssi_threshold:-78, backoff times:0, max:5<-78,-82,-85>
I (7416) mesh: [DONE]connect to parent:ESPM_CD2660, channel:6, rssi:-5, f4:12:fa
I (7426) mesh: set router bssid:0e:9a:3c:87:53:52
[22:29:38.284]收←◆I (7666) wifi
[22:29:39.279]收←◆I (8656) wifi:state: init -> auth (b0)
I (8676) wifi:state: auth -> assoc (0)
E (8686) wifi:Association refused temporarily, comeback time 1536 mSec
[22:29:40.837]收←◆I (10216) wifi:state: assoc -> assoc (0)
I (10236) wifi:state: assoc -> run (10)
I (10236) mesh: <MESH_NWK_MIE_CHANGE><><><><ROOT ADDR><><><>
I (10236) mesh: <MESH_NWK_ROOT_ADDR>from assoc, layer:2, root_addr:f4:12:fa
I (10236) mesh: <MESH_NWK_ROOT_ADDR>idle, layer:2, root_addr:f4:12:fa
I (10246) wifi:connected with ESPM_CD2660, aid = 1, channel 6, 40U, bssid = f4:12:fa
I (10256) wifi:security: WPA2-PSK, phy: bgn, rssi: -5
[0;32mI (10266) mesh_main: <MESH_EVENT_ROOT_ADDRESS>root address:f4:12:fa
[22:29:40.930]收←◆I (10316) wifi:pm start, type: 0
I (10316) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000
I (10316) mesh: [scan]new scanning time:600ms, beacon interval:300ms
I (10326) mesh: 2004<arm>parent monitor, my layer:2(cap:6)(node), interval:11599ms, retries:1<normal connected>
I (10326) wifi:BcnInt:102400, DTIM:1
[0;32mI (10336) mesh_main: <MESH_EVENT_PARENT_CONNECTED>layer:0-->2, parent:f4:12:fa
[0;32mI (10346) mesh_netif: It was a wifi station removing stuff[0m
[0;32mI (10356) mesh_main: <MESH_EVENT_TODS_REACHABLE>state:0[0m
[22:29:52.825]收←◆I (22206) mesh: 5156<active>parent layer:1(node), channel:6, rssi:-5, assoc:0(cnx rssi threshold:-120)my_assoc:0
[22:29:54.330]收←◆I (23716) mesh: 5947<scan>parent layer:1, rssi:-6, assoc:0(cnx rssi threshold:-120)
I (23716) mesh: [SCAN][ch:6]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][0e:9a:3c:87:53:52]<weak>
I (23716) mesh: 7369[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (23726) mesh: 716[monitor]no change, parent:f4:12:fa
I (23736) mesh: 2004<arm>parent monitor, my layer:2(cap:6)(node), interval:11860ms, retries:2<>
[22:30:06.507]收←◆I (35886) mesh: 5156<active>parent layer:1(node), channel:6, rssi:-5, assoc:0(cnx rssi threshold:-120)my_assoc:0
[22:30:08.010]收←◆I (37396) mesh: 5947<scan>parent layer:1, rssi:-6, assoc:0(cnx rssi threshold:-120)
I (37396) mesh: [SCAN][ch:6]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][0e:9a:3c:87:53:52]<weak>
I (37396) mesh: 7369[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (37406) mesh: 716[monitor]no change, parent:f4:12:fa
I (37416) mesh: 2004<arm>parent monitor, my layer:2(cap:6)(node), interval:4639ms, retries:3<>
[22:30:12.792]收←◆I (42176) mesh: 5156<active>parent layer:1(node), channel:6, rssi:-5, assoc:0(cnx rssi threshold:-120)my_assoc:0
[22:30:14.297]收←◆I (43676) mesh: 5947<scan>parent layer:1, rssi:-5, assoc:0(cnx rssi threshold:-120)
I (43676) mesh: [SCAN][ch:6]AP:1, other(ID:0, RD:0), MAP:1, idle:0, candidate:1, root:1, topMAP:0[c:2,i:2][0e:9a:3c:87:53:52]<weak>
I (43686) mesh: 7369[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (43696) mesh: 716[monitor]no change, parent:f4:12:fa
I (43706) mesh: 2004<arm>parent monitor, my layer:2(cap:6)(node), interval:301531ms, retries:3<>
求大佬们帮忙看一下
