Hi Guys,
I have been working on my own custom esp32-s3 epaper watch. I have manged to get it all working know apart from the I2C bus. I'm not sure why it is not working. I am using Arduino ide to program with the ESP32-s3 Dev board.
I have tried to initiate all the sensors using normal wire and twowire. Tried using multiple different I2C scanners but they all say that no devices found. Schematics and PCB below.
If anyone has any ideas on how to fix it then help would be great. Thanks.
Esp32-s3 Custom PCB. I2C not working.
MrT Stephens
- Watchy-MrT-ESP32-S3-V1.zip
- PCB zip file.
- (278.31 KiB) Downloaded 235 times
- Watchy-MrT-ESP32-S3-V1.pdf
- Schematic.
- (287.98 KiB) Downloaded 276 times
Re: Esp32-s3 Custom PCB. I2C not working.
Can you use a scope or LA to look at the signals on the I2C pins?
MrT Stephens
Hi,Can you use a scope or LA to look at the signals on the I2C pins?
Thanks for your reply. I don't actually have one. Do you know of any cheap ones I can get just for this use?
Would a picoscope work? "https://www.picotech.com/oscilloscope/2 ... 0-overview" as i have used these in college and they seemed to be decent.
Thanks, Tom
https://www.google.com/search?q=saleae+clone+8+channels
Some are under $10 and should be enough for I2C and other slow speed protocols (<10MHz).
MrT Stephens
Ahh ok thanks i will order one so i can test the I2C.https://www.google.com/search?q=saleae+clone+8+channels
Users browsing this forum: ChatGPT-User, DuckDuckGo [Bot], Google [Bot], trendictionbot and 1 guest
