ESP32S2烧录时提示没有WIFI\Flash\PSRAM 应该怎么解决
SY-TEC
Postby SY-TEC » Tue Sep 27, 2022 7:43 am
esptool.py v3.2-dev
Serial port COM27
Connecting.....
Chip is ESP32-S2
Features: WiFi, No Embedded Flash, No Embedded PSRAM, ADC and temperature sensor calibration in BLK2 of efuse V1
Crystal is 40MHz
MAC: 7c:df:a1:00:96:3a
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffff01, SizeID=0xff), defaulting to 4MB
Flash will be erased from 0x00001000 to 0x00006fff...
Flash will be erased from 0x00010000 to 0x0004dfff...
Compressed 21888 bytes to 13585...
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
The terminal process "E:\APP_software_Install\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe 'E:\APP_software_Install\Espressif\frameworks\esp-idf-v4.4\components\esptool_py\esptool\esptool.py', '-p', 'COM27', '-b', '460800', '--before', 'default_reset', '--after', 'hard_reset', '--chip', 'esp32s2', 'write_flash', '--flash_mode', 'dio', '--flash_freq', '80m', '--flash_size', 'detect', '0x1000', 'bootloader/bootloader.bin', '0x10000', 'esp32-s2-hmi.bin', '0x8000', 'partition_table/partition-table.bin'" terminated with exit code: 2.
yake827
Re: ESP32S2烧录时提示没有WIFI\Flash\PSRAM 应该怎么解决
Postby yake827 » Mon Oct 10, 2022 8:06 am
你这个是芯片已经进入下载模式,但是跟flash通信不稳定,常见于供电不稳定或者下载的USB转串口不好
Users browsing this forum: Google [Bot] and 2 guests
