OTA erro:E (26646) esp_ota_ops: not found ota data
aih5165
Postby aih5165 » Tue Sep 12, 2017 12:08 pm
How can I do with this?
I (26646) ota: Starting OTA example...
assertion "configured == running" failed: file "G:/esp32/msys32/home/chengh/esp/gsc/user/ota.c", line 199, function: ota_ex
mple_task
abort() was called at PC 0x400d1d13 on core 0
0x400d1d13: __assert_func at /Users/ivan/e/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/stdlib/
./../../.././newlib/libc/stdlib/assert.c:63 (discriminator 8)
Backtrace: 0x40087358:0x3ffcfe30 0x40087457:0x3ffcfe50 0x400d1d13:0x3ffcfe70 0x400e0954:0x3ffcfea0
0x40087358: invoke_abort at G:/esp32/msys32/home/chengh/esp/esp-idf/components/esp32/panic.c:547
0x40087457: abort at G:/esp32/msys32/home/chengh/esp/esp-idf/components/esp32/panic.c:547
0x400e0954: ota_example_task at G:/esp32/msys32/home/chengh/esp/gsc/user/ota.c:199 (discriminator 1)
Rebooting...
ets Jun 8 2016 00:22:57
rinripper
Re: OTA erro:E (26646) esp_ota_ops: not found ota data
Postby rinripper » Tue Feb 06, 2018 9:44 pm
Hi, you could do something about this error, I'm having the same.
Thanks in advance (sorry for my bad english)
Mauricio
burgersonbrioche
Postby burgersonbrioche » Wed May 08, 2019 11:50 pm
In order to flash an ota partition you need to setup the partition table correctly.
You will need minimum 2 partitions for the firmware binary which should be big enough to fit the entire binary as well as a data partition which stores information about the ota firmware partions.
here is an example csv partion table
# Name,   Type, SubType,  Offset,   Size,  Flags
reserved, data, 0xfe,     0x9000,   16k
otadata,  data, ota,      0xd000,   8k      #ota data (partition info)
phy_init, data, phy,      0xf000,   4k
ota_0,    app,  ota_0,    0x10000,  1920k   # ota firmware partion 0
ota_1,    app,  ota_1,    ,         1920k   # ota firmware partion 1
coredump, data, coredump, ,         64K
nvs,      data, nvs,      ,         128K
would have to see your partition table if you have already made one. But the "esp_ota_ops: not found ota data" error sees to indicate a the the otadata partition is missing.
"If you're gunna do it more than once, Automate it!"
--Burgers On Brioche
Users browsing this forum: Qwantbot, Semrush [Bot] and 2 guests
