esp32s3 enabling ext1 into deepsleep in esp-idf v4.4.1 environment will trigger a power-on reset
Zakiu-C
Postby Zakiu-C » Wed Oct 19, 2022 6:03 am
log as follows:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x1714
load:0x403b6000,len:0xb7c
load:0x403ba000,len:0x3094
entry 0x403b6248
I (24) boot: ESP-IDF v4.4.1-dirty 2nd stage bootloader
I (25) boot: compile time 10:52:31
I (25) boot: chip revision: 0
I (27) boot.esp32s3: Boot SPI Speed : 80MHz
I (32) boot.esp32s3: SPI Mode : DIO
I (36) boot.esp32s3: SPI Flash Size : 2MB
I (41) boot: Enabling RNG early entropy source...
I (47) boot: Partition Table:
I (50) boot: ## Label Usage Type ST Offset Length
I (57) boot: 0 nvs WiFi data 01 02 00009000 00006000I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000I (72) boot: 2 factory factory app 00 00 00010000 00100000I (80) boot: End of partition table
I (84) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=07f50h (
32592) map
I (98) esp_image: segment 1: paddr=00017f78 vaddr=3fc91e60 size=02774h (
10100) load
I (103) esp_image: segment 2: paddr=0001a6f4 vaddr=40374000 size=05924h ( 22820) load
I (114) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=1778ch ( 96140) map
I (135) esp_image: segment 4: paddr=000377b4 vaddr=40379924 size=08530h ( 34096) load
I (143) esp_image: segment 5: paddr=0003fcec vaddr=50000000 size=00010h ( 16) load
I (143) esp_image: segment 6: paddr=0003fd04 vaddr=600fe000 size=00028h ( 40) load
I (155) boot: Loaded app from partition at offset 0x10000
I (155) boot: Disabling RNG early entropy source...
I (172) cpu_start: Pro cpu up.
I (172) cpu_start: Starting app cpu, entry point is 0x403751e8
0x403751e8: call_start_cpu1 at H:/ESP32/Espressif/frameworks/esp-idf-v4.4.1/esp-idf-v4.4.1/components/esp_system/port/cpu_start.c:160
I (0) cpu_start: App cpu up.
I (186) cpu_start: Pro cpu start user code
I (186) cpu_start: cpu freq: 160000000
I (186) cpu_start: Application information:
I (189) cpu_start: Project name: deep_sleep
I (194) cpu_start: App version: 1
I (199) cpu_start: Compile time: Oct 19 2022 10:51:47
I (205) cpu_start: ELF file SHA256: d221e5cbd6a9a6da...
I (211) cpu_start: ESP-IDF: v4.4.1-dirty
I (216) heap_init: Initializing. RAM available for dynamic allocation:
I (223) heap_init: At 3FC94FD8 len 0004B028 (300 KiB): D/IRAM
I (230) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM
I (236) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (243) heap_init: At 600FE028 len 00001FC8 (7 KiB): RTCRAM
I (249) spi_flash: detected chip: generic
I (254) spi_flash: flash io: dio
W (257) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (271) sleep: Configure to isolate all GPIO pins in sleep state
I (278) sleep: Enable automatic switching of GPIO sleep configuration
I (285) cpu_start: Starting scheduler on PRO CPU.
core 0: 01 core 1: 01
Not a deep sleep reset
Enabling EXT1 wakeup on pins GPIO2, GPIO4
Entering deep sleep
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0xb (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
entry 0x403b6248
32592) map
10100) load
Entering deep sleep
It seems that triggering ext1 wakeup will cause this problem, but I'm not sure.
The code is as follows:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "sdkconfig.h"
#include "freertos/task.h"
#include "esp_sleep.h"
#include "esp_log.h"
#include "driver/rtc_io.h"
#include "rom/rtc.h"
void app_main(void)
printf("core 0: %02x\tcore 1: %02x\r\n", rtc_get_reset_reason(0), rtc_get_reset_reason(1));
switch (esp_sleep_get_wakeup_cause()) {
#ifdef CONFIG_EXAMPLE_EXT1_WAKEUP
case ESP_SLEEP_WAKEUP_EXT1: {
uint64_t wakeup_pin_mask = esp_sleep_get_ext1_wakeup_status();
if (wakeup_pin_mask != 0) {
int pin = __builtin_ffsll(wakeup_pin_mask) - 1;
printf("Wake up from GPIO %d\n", pin);
printf("Wake up from GPIO\n");
#endif // CONFIG_EXAMPLE_EXT1_WAKEUP
case ESP_SLEEP_WAKEUP_UNDEFINED:
default:
printf("Not a deep sleep reset\n");
const int ext_wakeup_pin_1 = 2;
const uint64_t ext_wakeup_pin_1_mask = 1ULL << ext_wakeup_pin_1;
const int ext_wakeup_pin_2 = 4;
const uint64_t ext_wakeup_pin_2_mask = 1ULL << ext_wakeup_pin_2;
printf("Enabling EXT1 wakeup on pins GPIO%d, GPIO%d\n", ext_wakeup_pin_1, ext_wakeup_pin_2);
esp_sleep_enable_ext1_wakeup(ext_wakeup_pin_1_mask | ext_wakeup_pin_2_mask, ESP_EXT1_WAKEUP_ANY_HIGH);
printf("Entering deep sleep\n");
esp_deep_sleep_start();
I don't see any record of this in the 4.4.2 update in github, so if any of you know why, please let me know.
Users browsing this forum: Bing [Bot], Google [Bot], meta-externalagent and 2 guests
