ESP32-S2 High Frequency PWM Issues
I'm having issues getting PWM above 30khz, I'm using the Arduino Framework and using the LEDC functions. Resolution is 10bit and should be able to get 78khz. If I run the same code on standard ESP32 I can get the 78khz. So it seems to be an issue with the S2 version. From digging through docs I see something about low speed, but it can still use the 80mhz timer. Is there any additional parameters I need to set? Thanks
Users browsing this forum: PerplexityBot and 2 guests
