Getting TG0WDT_SYS_RESET in latest code.
harishjp
Postby harishjp » Thu Sep 14, 2017 5:55 pm
I'm getting the following error continuously in the latest esp32 arduino master.
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO
I've attached the full serial output. The code works if I use and older version: commit hash 856823ef195ef5c28516395356e8a30f8af8e917. I've not tried doing a git bisect to see which patch introduced this. Why is this happening?
The code is approximately following:
static volatile unsigned long data[1000] = {0};
static volatile uint32_t coreid[1000] = {0};
static volatile long idx = 0;
static volatile long last;
void __zx_isr() {
  unsigned long ccount;
  __asm__ __volatile__ ( "rsr     %0, ccount" : "=a" (ccount) );
  if (idx == 1000) {
    return;
  data[idx] = ccount;
  coreid[idx] = xPortGetCoreID();
  ++idx;
void test_zerocrossing() {
  uint32_t pin = 35;
  pinMode(pin, INPUT);
  // Setup an interrupt routine.
  attachInterrupt(pin, __zx_isr, CHANGE);
  Serial.println("Attaching interrupt ...");
  while (idx != 1000) {
    delay(1000);
  Serial.println("Reached counter dumping data");
  Serial.printf("Cpu freq: %d\n", CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ);
  for (int i = 2; i < 1000; ++i) {
    Serial.printf("Core: %d, Last: %d, Cur: %d, Diff: %d\n", coreid[i], data[i - 1], data[i], data[i] - data[i - 1]);
extern "C" void app_main() {
  initArduino();
  // This code will go away in non test mode.
  pinMode(2, OUTPUT);
  Serial.println("Start test ...");
  test_zerocrossing();
  Serial.println("Finished test ...");
esp32_out.txt
(3.7 KiB) Downloaded 750 times
harishjp
Re: Getting TG0WDT_SYS_RESET in latest code.
Postby harishjp » Wed Sep 20, 2017 12:54 am
I started getting watchdog timer reset for this code too:
   initArduino();
  for (;;) {
    Serial.println(touchRead(T0));
    delay(100);
But it stopped coming as soon as I split it into setup and loop. I looked at main.cpp. The the only thing different is that loop runs on a different core. Is this expected?
ESP_Me-no-dev
Postby ESP_Me-no-dev » Wed Sep 20, 2017 6:45 am
try to change
void __zx_isr()
to
void IRAM_ATTR __zx_isr()
