Tried to update ESP-IDF and everything broke
ZacDaMan
Postby ZacDaMan » Fri Oct 21, 2022 2:28 am
I use ESP-IDF through VSCode; I have the extension, which is primarily how I build projects. I previously had ESP-IDF version 3.1.somethingorother installed, which was working, but I wanted to update to the latest. I cleared out my install folder (F:\Users\Isaac\esp-idf) and ran the installation tool, esp-idf-tools-setup-online-2.16.exe. This ran without any errors popping up, but now when I go to build a project (using the cylinder icon in vscode) it outputs this:
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.19.0.windows.1")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: F:/Users/Isaac/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe
-- Check for working C compiler: F:/Users/Isaac/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe
-- Check for working C compiler: F:/Users/Isaac/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe -- works
-- Check for working CXX compiler: F:/Users/Isaac/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-g++.exe
-- Check for working CXX compiler: F:/Users/Isaac/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-g++.exe -- works
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32c3
-- Project sdkconfig file F:/Users/Isaac/Documents/ESP-IDF/onoff_server/sdkconfig
Loading defaults file F:/Users/Isaac/Documents/ESP-IDF/onoff_server/sdkconfig.defaults...
Loading defaults file F:/Users/Isaac/Documents/ESP-IDF/onoff_server/sdkconfig.defaults.esp32c3...
CMake Error at F:/Users/Isaac/esp-idf/tools/cmake/crosstool_version_check.cmake:37 (message):
  Toolchain:
  F:/Users/Isaac/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe,
  crosstool-ng version esp-2021r1 doesn't match supported version
  esp-2021r2-patch3
  Please try to run 'idf.py fullclean' to solve it quickly.
  Check Getting Started documentation if the error continues.
  You can override this error and proceed with build by defining the
  IDF_MAINTAINER environment variable.
  F:/Users/Isaac/esp-idf/components/esp_common/project_include.cmake:7 (crosstool_version_check)
  F:/Users/Isaac/esp-idf/tools/cmake/build.cmake:325 (include)
  F:/Users/Isaac/esp-idf/tools/cmake/build.cmake:534 (__build_process_project_includes)
  F:/Users/Isaac/esp-idf/tools/cmake/project.cmake:384 (idf_build_process)
  CMakeLists.txt:8 (project)
See also "F:/Users/Isaac/Documents/ESP-IDF/onoff_server/build/CMakeFiles/CMakeOutput.log".
See also "F:/Users/Isaac/Documents/ESP-IDF/onoff_server/build/CMakeFiles/CMakeError.log".
 *  The terminal process "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 .." terminated with exit code: 1.
Additionally, I get messages saying something like "Run idf.py", but I seem to be completely unable to do this. Running `idf.py fullclean` from a terminal inside the project folder, I get
PS F:\Users\Isaac\Documents\ESP-IDF\onoff_server> idf.py fullclean
idf.py : The term 'idf.py' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is
correct and try again.
At line:1 char:1
+ idf.py fullclean
    + CategoryInfo          : ObjectNotFound: (idf.py:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
I have added IDF_PATH as
to my system variables and added
%IDF_PATH%\tools
to my path.
Help?
HPekiM
Re: Tried to update ESP-IDF and everything broke
Postby HPekiM » Sat Oct 22, 2022 9:10 am
same problem here :/
HPekiM
Postby HPekiM » Sat Oct 22, 2022 9:24 am
Adding environment variable IDF_MAINTAINER (set to '1') - as suggested in the above shown error message - fixed it!
ZacDaMan
Postby ZacDaMan » Mon Oct 24, 2022 7:59 pm
I also tried defining IDF_MAINTAINER, and it does build, but I'm worried that ignoring the error like that could have a negative impact and would like to fix the issue if possible.
Users browsing this forum: Applebot, Baidu [Spider], Qwantbot and 1 guest
