I've built a project with esp-wroom-32 and after a few days of running, the esp32 turned off and when I connected it to my computer it started smoking.
I'm not sure what made it happen, it's the second time it has happened to me with this project.
I made a schematic of my project so you guys can see it and hopefully find what's wrong with it.
The servo is connected to a relay so it's not on all the time (because it's making noise), it's turned on only when I want to move the servo.
I trigger the servo to move using WIFI or using the push button.
I suspect that the relay made the esp32 burn because it drew too much current from the 3v3 pin, if it's the case, I would be happy if someone can suggest me another way to power up the relay (I tried using an external 5v but it won't work because the signal is connected to 3v GPIO)
