Uploading to SPIFFS: "invalid head of packet" error
pauldupuyjr
Postby pauldupuyjr » Thu Nov 03, 2022 11:07 pm
I can upload and monitor working code in PlatformIO and Arduino IDE (on Windows 11) but can't upload a small data file to a SPIFFS partition on an Unexpected Maker ProS3 (ESP32-S3).
PlatformIO 2.5.5 output from verbose "Upload Filesystem Image":
C:\Users\***\.platformio\penv\Scripts\platformio.exe run --target uploadfs --environment esp32s3 -v
Processing esp32s3 (framework: arduino; platform: espressif32; board: um_pros3; lib_extra_dirs: lib; build_flags: -DARDUINO_USB_MODE=1; monitor_port: COM8; upload_port: COM8; upload_speed: 115200; monitor_speed: 14400; board_build.partitions: large_spiffs_16MB.csv)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/um_pros3.html
PLATFORM: Espressif 32 (5.2.0) > Unexpected Maker PROS3
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
 - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
 - tool-esptoolpy @ 1.40201.0 (4.2.1)
 - tool-mkfatfs @ 2.0.1
 - tool-mklittlefs @ 1.203.210628 (2.3)
 - tool-mkspiffs @ 2.230.0 (2.30)
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 48 compatible libraries
Scanning dependencies...
Dependency Graph
|-- Wire @ 2.0.0 (License: Unknown, Path: C:\Users\***\.platformio\packages\framework-arduinoespressif32\libraries\Wire)
|-- XT_DAC_Audio @ 4.2.1 (License: Unknown, Path: ***\lib\XT_DAC_Audio)
|-- ESP32 BLE Arduino @ 2.0.0 (License: Unknown, Path: C:\Users\***\.platformio\packages\framework-arduinoespressif32\libraries\BLE)
|-- WiFi @ 2.0.0 (License: Unknown, Path: C:\Users\***\.platformio\packages\framework-arduinoespressif32\libraries\WiFi)
|-- SPIFFS @ 2.0.0 (License: Unknown, Path: C:\Users\***\.platformio\packages\framework-arduinoespressif32\libraries\SPIFFS)
|   |-- FS @ 2.0.0 (License: Unknown, Path: C:\Users\***\.platformio\packages\framework-arduinoespressif32\libraries\FS)
|-- FastLED @ 3.5.0 (License: MIT, Path: ***\lib\FastLED-3.5.0)
|   |-- SPI @ 2.0.0 (License: Unknown, Path: C:\Users\***\.platformio\packages\framework-arduinoespressif32\libraries\SPI)
Building in release mode
"mkspiffs_espressif32_arduino" -c data -s 7274496 -p 256 -b 4096 build\esp32s3\spiffs.bin
/this.txt
BeforeUpload(["uploadfs"], ["build\esp32s3\spiffs.bin"])
Using manually specified: COM8
Forcing reset using 1200bps open/close on port COM8
Waiting for the new upload port...
"C:\Users\***\.platformio\penv\Scripts\python.exe" "C:\Users\***\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32s3 --port "COM8" --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 16MB 9502720 build\esp32s3\spiffs.bin
esptool.py v4.2.1
Serial port COM8
Connecting...
Chip is ESP32-S3
Features: WiFi, BLE
Crystal is 40MHz
MAC: f4:12:fa:42:0c:20
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00910000 to 0x00ffffff...
Compressed 7274496 bytes to 13119...
Writing at 0x00910000... (100 %)
A fatal error occurred: Invalid head of packet (0x6F): Possible serial noise or corruption.
*** [uploadfs] Error 2
Using Arduino IDE 1.8.19 (with a simple ino) and https://github.com/lorol/arduino-esp32fs-plugin:
Chip : esp32s3
Using partition scheme from Arduino IDE.
Start: 0x910000
mkspiffs : C:\Users\***\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3\mkspiffs.exe
esptool : C:\Users\***\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1\esptool.exe
[SPIFFS] data   : C:\Users\***\Documents\Arduino\sketch_nov2a\data
[SPIFFS] offset : 0
[SPIFFS] start  : 9502720
[SPIFFS] size   : 7104
[SPIFFS] page   : 256
[SPIFFS] block  : 4096
->/test.txt
[SPIFFS] upload : C:\Users\***\AppData\Local\Temp\arduino_build_460733/sketch_nov2a.spiffs.bin
[SPIFFS] address: 9502720
[SPIFFS] port   : COM8
[SPIFFS] speed  : 115200
[SPIFFS] mode   : dio
[SPIFFS] freq   : 80m
->esptool.py v4.2.1
->Serial port COM8
->Connecting...
->Chip is ESP32-S3
->Features: WiFi, BLE
->Crystal is 40MHz
->MAC: f4:12:fa:42:0c:20
->Uploading stub...
->Running stub...
->Stub running...
->Configuring flash size...
->Auto-detected Flash size: 16MB
->Flash will be erased from 0x00910000 to 0x00ffffff...
->Compressed 7274496 bytes to 13119...
->Writing at 0x00910000... (100 %)
->A fatal error occurred: Invalid head of packet (0x6F): Possible serial noise or corruption.
SPIFFS Upload failed!
In USBDeview, the device shows connected and enabled with COM8 drive letter and Microsoft USB Serial Device driver.
I've tried multiple short USB cables and get the same result on both a Windows 11 Pro 22H2 and Windows 10 Pro 21H2 computer.
Thanks in advance for your help.
ccharlton
Re: Uploading to SPIFFS: "invalid head of packet" error
Postby ccharlton » Thu Nov 10, 2022 5:49 pm
I'm experiencing the exact same error with Unexpected Maker TinyS3 and Feather S3 boards.
I've attached a trace of the error.
trace.txt
(101.84 KiB) Downloaded 216 times
ccharlton
Postby ccharlton » Sun Nov 13, 2022 8:58 am
We've narrowed down the issue to the partition tables and I've opened issues in the appropriate GitHub repos:
https://github.com/espressif/esptool/issues/795
https://github.com/espressif/arduino-esp32/issues/7467
Users browsing this forum: Bytespider and 3 guests
